Modern suspension on a 69
Old Apr 8, 2012 | 04:24 PM
694free's Avatar
I just picked up a 69 hardtop that started life as a base I6 200 with the 3 speed. Now it's got an 87 5.0 and a half-*** installed C6. In the next few months I would like to upgrade the suspension and brakes from a newer GT or another ford product that's compatible without spending a fortune. Any tips or advise would be great. Thank you.
Old Apr 10, 2012 | 06:27 PM
dmay65's Avatar
Go and IRS from an 03 cobra and mustang 2 font end
Old Apr 10, 2012 | 06:31 PM
dmay65's Avatar
The late model stuff really isn't transferable and if you want it, it's a lot of fab. If you want good handling for cheap, go stiff rear springs, some good gas adjusts, sway bar, trac bars and your good to go. Front either mustang 2 or just replace all stock bushings, go stiffer coils, gas adjusts again, thicker sway bar, poly tie rod bushings, and probably a one piece export brace and a monte bar. And subframes possibly. Nothings cheap but do the labor yourself
Old Apr 11, 2012 | 07:56 AM
694free's Avatar
Somebody before me must have changed the rear axle because it's got a 5 lug hub and the front has only 4. How will that effect the parts I get?
Old Apr 11, 2012 | 10:24 AM
dmay65's Avatar
If you buy a mustang 2 front clip it'll change the 4 lug over to 5 anyway. You don't want 4 lug it's weaker. If the rear end is 5 already then you can just do the rear upgrades I said
May 3, 2026 05:42 AM
GeoWett
Sep 30, 2015 06:40 AM
seaclam
Sep 25, 2015 01:29 PM
Evil_Capri
Sep 25, 2015 12:56 PM
BavarianStang
Sep 5, 2015 05:55 AM
