Mach 1 deluxe interior clock fix
Old Apr 15, 2007 | 12:07 AM
tricksixtyfive's Avatar
1970 mach 1. I am converting my clock to quartz. i am having trouble removing the deluxe interior panel, the dash pad blocks getting to it. is there a special way of removing this panel. Anyone have any tips?
Old Apr 15, 2007 | 04:49 PM
future9er24's Avatar
Not too related but effin sweet avatar
Old Apr 15, 2007 | 09:22 PM
thanks - i made the avatar myself. if anyone wants one let me know..
Old Apr 16, 2007 | 03:03 PM
rickoshay's Avatar
I used to own a '70 Mach (w/o ac) and have removed the clock from the dash panel without disassembling the dash/clock panel. You'll need to remove the plastic glove box from the glove box door & the gb door limiting cable to gain access from underneath.
Reach up behind the clock, unplug the power lead & remove the lights (they twist 1/4 turn). IIRC, you'll need a 5/16 (or 1/4) socket to remove the three mounting screws.
This may not work if your car has ac. Good luck!
Old Apr 16, 2007 | 08:21 PM
my car has ac but i will look into it thanks any hints help
Old Apr 17, 2007 | 01:51 PM
rickoshay's Avatar
If you still can't get to the clock from underneath I don't think you'll have any choice but to remove the dash pad (very carefully). In addition to the six clock panel screws you can get to (three each into the pad & also into the metal part of dash), there is a mounting "ear" on either side of the panel that can only be accessed from the back side of the panel.
Most of the time these tabs were broken or the screws were not reused if the dash had been previously disassembled, but they could still be intact.
Old May 9, 2007 | 10:10 PM
my speedo just went out it kills me that i have to remove my dash pad for both of these..my 65 was way easier to work on...how far they came technologically (if i spelt that right) in 5 years..
Old May 9, 2007 | 10:51 PM
Knight's Avatar
Needs to be more Astony
yeah its pretty amazing how much different built the 1965s are to the 1970's
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
TerryD
Sep 28, 2015 11:48 AM
Mustang65bob
Sep 21, 2015 11:30 AM
