JBA AOD H-Pipe does not fit an AOD or a 'vert
Originally posted by LMan@July 6, 2004, 9:29 AM
sheesh.....head for the light, Jay......a T-5Z will fit juuuuuuuuuuust fine in there....
Small update. Here is a pic of the pipe that I received:
Here is where I am at using my own collection of S-Bends (mandrel) from Flowmaster, combined with the ends of the JBA pipe. You can see I have 2 cross braces tacked in to hold the shape while the unit is off the car and I drill and mount the crossover:
I should flip one to show just how dramatic the difference is. Like I mentioned in my other post (or meant to) it's becoming more and more common for manufacturers to insist some modification will be necessary on your part (this is a BS out --- not at these prices should this be true).
Originally posted by jpony645+July 6, 2004, 9:40 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (jpony645 @ July 6, 2004, 9:40 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-LMan@July 6, 2004, 8:31 AM
you have your exh pipes tucked up in your d/s tunnel?
I'm with Jay....go tunnel or go home. [/b][/quote]
Beats me. Mine are in the tunnel (mostly, IIRC) and I dont have these issues. Of course, I dont have a big fat AOD case and pan to fit in there either
Acres of room here!
________
Live sex webshows
Acres of room here!
Acres of room here!
Geez, that stinks. How big is that driveshaft anyway? I know folks that have 2.5 inch pipes that fit in 65-66 verts. How many kewl points would you lose if you went back with the stock driveshaft? Of course, that's only ONE of your problems.
Note for lower class fastback and coupe owners: Verts have a heavy plate that connects floorpans. The driveshaft and exhaust pipes must fit between tranny tunnel and this plate.
It sure takes a lot of patience to be the first one on the block.
This plate also requires additional pans under the seat pans that square the tunnel off and give up further tunnel width.
Originally posted by Jay+July 19, 2004, 7:11 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Jay @ July 19, 2004, 7:11 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin-LMan@July 19, 2004, 8:50 AM
Beats me.?? Mine are in the tunnel (mostly, IIRC) and I dont have these issues.?? Of course, I dont have a big fat AOD case and pan to fit in there either??
?? ?? Acres of room here!??
[/b][/quote]oh yeah! Thanks for reminding me!
Don't take your "Wish-I-boughta-fastback-thats-now-worth-more-than-verts" frustrations out on me....
________
Harmed By Zoloft
Gigantor
May 11, 2023 07:31 PM
Sep 24, 2015 08:15 PM
