Help Can't get headlight knob Off
I am changing my headlight switch right now,,!! and cannot seem to get that chrome **** to come off the square shatf WTF????????? I s the a trick or is it I just break the f'in thing off..I am getting frustrated and losing light PLEASE HELP
Did you get it? I had difficulties when I removed mine last month. It is a two part process. The key is at the top of the switch box. There is a spring loaded button on the top (it's the only thing on the smooth flat top portion. Push the button down, and pull the **** out(at the same time). Next, us a large flat screw driver to unscrew the center section out of the switch box.
That should do it, hope it works for you.
Craig
Yes there is a small button on the switch. Behind the dash. It is kind of hard to reach, push it it, then pull out the ****. It will come out with the shaft attached. Then unscrew the bezel from the switch.
Other posts have outlined the proceedure for removing the ****/shaft from the switch.
Isn't there a small set screw in the bottom of it? An Allen head screw, maybe? I can't remember exactly.
:nono:
:nono:
I got it!!!!! well kinda i had my niegbor come over and he used a cutting tool to cut the shaft then we broke apart the old switch to get the shasft out welded it back together and "viola" It wasn't pretty and my **** is half hiney but now i got headlights that work. I will have to get a new one and follow procedure because pullng on the old one with my locking plyers didn't work...Thanks everyone.
:scratch:
i cut the **** off because the friggin thing was impossible to remove the **** and shaft from my old switch..I did it wrong i know, but i could not get this to pull out of the old switch..and i could not remove the switch, the **** would not fit thru the hole with the nut and bezel...So I butchered it..but all is well.
