Help Can't get headlight knob Off
Old Mar 13, 2005 | 01:57 PM
tricksixtyfive's Avatar
I am changing my headlight switch right now,,!! and cannot seem to get that chrome **** to come off the square shatf WTF????????? I s the a trick or is it I just break the f'in thing off..I am getting frustrated and losing light PLEASE HELP
Old Mar 13, 2005 | 03:18 PM
Paul's Avatar
Isn't there a small set screw in the bottom of it? An Allen head screw, maybe? I can't remember exactly.
Old Mar 13, 2005 | 10:03 PM
beneman's Avatar
Chris,
Did you get it? I had difficulties when I removed mine last month. It is a two part process. The key is at the top of the switch box. There is a spring loaded button on the top (it's the only thing on the smooth flat top portion. Push the button down, and pull the **** out(at the same time). Next, us a large flat screw driver to unscrew the center section out of the switch box.
That should do it, hope it works for you.
Craig
Old Mar 13, 2005 | 10:30 PM
67fastback428's Avatar
Yes there is a small button on the switch. Behind the dash. It is kind of hard to reach, push it it, then pull out the ****. It will come out with the shaft attached. Then unscrew the bezel from the switch.
Old Mar 14, 2005 | 08:14 AM
Coupe's Avatar
Unfortunately the **** does not come off the shaft....... :nono:
Other posts have outlined the proceedure for removing the ****/shaft from the switch.
:nono: :nono:
Old Mar 14, 2005 | 11:01 AM
I got it!!!!! well kinda i had my niegbor come over and he used a cutting tool to cut the shaft then we broke apart the old switch to get the shasft out welded it back together and "viola" It wasn't pretty and my **** is half hiney but now i got headlights that work. I will have to get a new one and follow procedure because pullng on the old one with my locking plyers didn't work...Thanks everyone.
Old Mar 14, 2005 | 01:00 PM
Coupe's Avatar
I stand corrected...... apparently the **** does come off, with the appropriate tool :scratch:
Old Mar 14, 2005 | 01:25 PM
jpony645's Avatar
I don't quite understand why you even had to take the **** off in the first place. :scratch: It doesn't have to come off to take the switch out.
Old Mar 14, 2005 | 03:15 PM
i cut the **** off because the friggin thing was impossible to remove the **** and shaft from my old switch..I did it wrong i know, but i could not get this to pull out of the old switch..and i could not remove the switch, the **** would not fit thru the hole with the nut and bezel...So I butchered it..but all is well.
Jul 8, 2016 08:53 AM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
K.A.I.N
Sep 25, 2015 03:27 PM
