Granada Brake Swap
Old Mar 18, 2005 | 08:24 AM
  #41
69gmachine's Avatar
Originally posted by ultrastang+March 18, 2005, 12:01 AM--><div class='quotetop'>QUOTE(ultrastang @ March 18, 2005, 12:01 AM)</div><div class='quotemain'>
Originally posted by 69gmachine@March 17, 2005, 10:23 AM
<!--QuoteBegin-ultrastang
@March 16, 2005, 10:53 PM
The '75-'80 Granadas/Mercury Monarchs share the same front suspension dimensions and geometry as the '67-'70 Mustangs. The 'Granada' front disc brake swap has no adverse affects on these models, even when the suspension is altered (lowered).
Some '65/'66 models do experience problems with this swap --particularly when the car has been lowered.
www.ultrastang.com
Hmmm, you must not have actually done this swap ! Instead of making subjective comments or making statements of faith, how about we use real data? I challenge anyone to take toe measurements with the granada spindle using a bump steer guage from +/- 2" @ 0.5" increments. Compare that to a 67-73 Mustang spindle. Then take both sets of measurements again with the 1" Shelby drop. I suspect we will find there is measureable bump steer with a stock spindle and stock location upper arm, it gets a little worse with a Granada spindle and stock upper arm, a stock spindle with the Shelby drop is significantly worse, and the Granada spindle with the Shelby drop is horrid. I have a Longacre bumpsteer guage, and am willing to take measurements on anyone's car that has any of the above configurations. (I am developing my own front suspension using Granada spindles with my own design upper arm that is neither stock nor the Shelby drop, and my own centerlink to get negligible bump steer so measuements on my car will not be valid for comparison, but I will gladly publish my results )
Hmmm...well lets' see now...I've installed the Granada setup on (1) '65 Mustang, (2) '66 Mustangs, (1) '67 Mustang, (1) '68 Mustang --my own, and on (1) '69 Mustang.
Of all these, the ONLY one that had problems was on one of the '66 Mustangs. I installed the Pro Motorsports Neg. Wedges on it, and had a terrible problem with the tires wearing out on the inner edges. Ended up taking the wedges out and returning the UCA's back to their stock location to stop the excessive tire wear issue.
My '68 is lowered 1" and I cut 3/4 of a coil off the front springs and I made and installed 1½" lowering blocks in the rear. All Mustangs will have some degree of bumpsteer in its stock form, but the Granada conversion did not add any more to the bumpsteer in my '68.
http://www.ultrastang.com/Images/Main.jpg
The red '68, pictured in the link above, is my car (my high school car --owned it for 22 years). I installed the Granada front discs and Granada 15/16" front swaybar on it in 1992. The Blue '65 belongs to a friend. I installed the Granada front discs on the '65 in 1996. Have had no problems with either one of them.
The main problem some experience with Granada discs on a '65/'66 Mustang is its narrower track width. --They are two inches narrower than the '67-'70/'75-'80 Granadas/Monarchs, and the Granada spindles have a little different geometrical configuration from the stock, early ('65/'66) Mustang spindles.
[/b][/quote]
It sounds like you have had a lot of fun with your cars You know from first hand experience that the Granada swap itself can work, and I'm not trying to convince you otherwise. You mentioned that your '68 was lowered 1", and you had lowering springs. It sounds like you lowered the UCA, and lowering the UCA vice using lowering springs has a greater effect on bumpsteer. On my previous '69 I used these same Granada spindles without lowering the upper arms and also had no problems even at 94 mph.
On my current '69 I lowered the arms about 1 3/8", and installed the Granada conversion from my old car. Perhaps there is an exponential increase in the toe-in as the arm is lowered beyond 1"? The tires wore out too fast, and the bumpsteer was outright dangerous at 80 mph. I don't have stock 67-73 Mustang spindles to compare too, but I imagine that either would get worse as it is lowered.
There are other considerations for why one car handles bettter than another with the same mods, and one is the tires. A tall and narrow tire will have a much greater slip angle than a shorter stiffer sidewall. I was running P255s on 15" rims at the time. All of my (early) Mustangs have been 69-70s, so I have no experience with the 65-66 cars, and they had significantly different suspension and steering geometry (narrower track, wider centerlink, different angle between the upper and lower arm pivots). I know they had smaller wheel wells, so I would guess you had smaller tires on them, which would help mask the bumpsteer.
I'm not trying to be a smart a##... with real data we can see what works and what doesn't. Where are the limits with lowering the upper arms, tire size, and the change in Ackerman from Granada spindles, and how that translates into increased bump steer? I know from my own first hand experience that there is a limit to lowering the stock suspension and using Granada spindles.
Old Mar 18, 2005 | 06:54 PM
  #42
ultrastang's Avatar
Originally posted by 69gmachine+March 18, 2005, 9:27 AM--><div class='quotetop'>QUOTE(69gmachine @ March 18, 2005, 9:27 AM)</div><div class='quotemain'>
www.ultrastang.com
[/b][/quote]
I didn't feel like you were trying to make an attack on me, so everything's cool. I've been tinkering and modifying on these cars for 26 years now. I got bitten by the Mustang bug when I was 13 (1979). I got my first Mustang two weeks before I turned 16 (1982) --the '68 that's shown in the picture from my previous post. It was my high school car. The blue '65 also shown in the photo belongs to an old classmate/friend of mine. He's owned it nearly as long as I've owned mine, and it was his high school car too. I'm 38 now, and still just as 'crazy' about Mustangs as I've always been
This is the latest project I'm working on --('94-2004) SN-95 Mustang rear disc brakes adapted to the Ford 8- & 9-inch rear end housings. This SN-95 10½", solid rotor design is a etup I adapted to another friend's '65 fastback. --Just have to figure out the parking brake cable now, and it'll be complete.
http://img177.exs.cx/img177/4066/dsc002702ma.jpg
--Well...I said this was my latest project. That's not totally true. I've just finished a bracket design to adapt the other SN-95 rear disc brake version to the early Ford rear end housings --the '94-2004 "Cobra" rear discs, which measures 11.65" in diameter and has a ventilated rotor. I plan to put this SN-95 rear disc version on my '68.
Old Mar 21, 2005 | 08:43 PM
  #43
degins's Avatar
www.ultrastang.com
You're correct, of course. I've accuately measured the positons of the mounting points on all types of spindles from 65-73. Although there are differences in the size of the outer tie rod mounting stud holes, the mounting geometry of the spindles from 67-73 and Granada are identical. The mounting position of the outer tie rod on the 65-66 spindles are about 1/2" different (outboard, backward, and downward). I suspect that the major cause of the problems that people have with this swap are related more to the other suspension mods that they do at the same time, than to the swap itself.
Old Mar 22, 2005 | 07:43 AM
  #44
jpony645's Avatar
Of course it has to do with the mods done in conjunction with the grenada swap. That's what has been being said. On a stock suspension 65/66 there is going to be a slight increase in the bumpsteer but nothing too significant. Now combine those spindles with lowered springs and/or lowered control arms and you have one heck of a mess.
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Ray11
Sep 25, 2015 12:43 PM
