Gas pedal travel
Old Mar 27, 2013 | 09:29 AM
les's Avatar
les
Gas pedal travel
Right now I am upgrading from a 2 bbl to a holley 4 bbl. my question if anyone noes the answer is this the gas pedal as she sits doesn't have much travel. When driving my other sports car It has more travel and just feels like you have more control of the throttle. Is there a way to adjust the pedal so that I can have a bit more travel?
Old Mar 27, 2013 | 02:26 PM
matcox83's Avatar
Can you shorten the linkage from the rod to the carb? Assuming it is stock setup. Does the carb throttle plate have full travel? Have you made the swap yet and is it different from the 2V, or you didn't like the 2V and anticipate the same feel?
Old Mar 27, 2013 | 02:37 PM
matcox83's Avatar
I made the assumption you were not getting full throttle plate travel in which case shortening the linkage might help. If your pedal doesn't move enough to give you more control, shortening the linkage would make it worse.
Old Mar 27, 2013 | 02:56 PM
ChrisM's Avatar
Here's the adjustment Matcox is talking about:
File Type: pdf
Gill5oh
Oct 6, 2017 10:50 PM
NC14GT
Sep 10, 2017 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
NC14GT
2007-2009 Mustang GT/CS
Sep 27, 2015 03:03 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
