Fuel Gauge reading Empty
Old Sep 21, 2004 | 12:32 PM
jsmth86's Avatar
On My 66 Mustang the fuel Gauge reads empty but it is full! When I turn the key off the needle goes below empty. But When I turn the key to on the needle moves just a little past the E. I dont think that it is the instrument pannel because the needle would not move at all or it would just would move to the F. I am thinking that it could be the Fuel level sender. I checked the wiring and it seems fine. Do you reccomend putting a cleaner in the fuel tank to maybe clean the sender?
What do you think??
jsmth
Old Sep 21, 2004 | 12:46 PM
GT350Clone's Avatar
Sounds like the sending unit has gone south to me.
For reference, the stock sending unit has ~73 ohms resistance at empty and ~10 ohms full, IIRC...
Old Sep 21, 2004 | 01:43 PM
gjz30075's Avatar
Don't put a cleaner in the tank. Most likely a wire has broken on the resistance coil. Your best bet is to get a new one. Run the tank down, jack up the front end and change it out.
charles's Avatar
you might have to change the float in the gas tank
NC14GT
Feb 20, 2023 09:42 AM
Fastnloud
Feb 15, 2016 05:21 PM
Sep 16, 2015 06:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
