C4 Leak
Old Aug 15, 2013 | 02:54 PM
Mystang68's Avatar
C4 Leak
I very frustrated with my C4 and need any advice out there. I can't get my transmission fluid pan to seal. I have tried different types of gaskets, gasket sealant, etc. I then ordered a new pan thinking the old one may be slightly warped and the new pan still leaks.
Anyone dealt with this before/ have any solutions that work to get the pan to seal?
Old Aug 15, 2013 | 03:48 PM
HOSS429's Avatar
legacy Tms Member
there are a multitude of things just above the pan that can seep down and mimic a gasket leak .. if a new pan did not solve the issue i`d look elsewhere .. try to flatten the bolt holes on your original pan with a hammer .. they can get puckered over the years and not seat flat ....
Old Aug 16, 2013 | 07:23 AM
67Drewstang's Avatar
You know what first went through my mind when I saw this title? "C4 Leak"? Yep. mind does. Just like everyone else.
It's possible to get them to seal, but unless I'm losing significant amounts of fluid, I don't sweat it.
HOSS429's advice is sound. Also look at your transmission mating surfaces, rather than the pan. Possible there is a crack or divot in the surface where the pan joins.
BTW, I am assuming you fastened the bolts in the correct order and that they were torqued with a calibrated torque wrench to the proper values?
Old Aug 16, 2013 | 10:54 AM
Mystang68's Avatar
They are torqued appropriately, but I didn't realize that there was a specific order to tighten them in.
Old Aug 16, 2013 | 01:51 PM
I checked, but couldn't find one, but my Dodge had an order. Here's what I found from another forum:
Once you remove the pan, using a ball pen hammer tap down any dimples
that
may be from over tightening previously.
Clean both surfaces very clean and dry. I like to use a little ( dont
over
do it ) RTV red on the pan smeared on with my finger ( be careful not
to
lick your fingers after ) once it has had a chance to setup a bit, set
the
good quality cork/rubber gasket ( like a McCord or FelPro ) gasket onto the
pan.
Start all the bolts, fron a center point out evenly snugup all the bolts.
I
generally do it to a snuf feel with a 1/4 ratchet.
Add the appropriate atf fluid and start, drive and test for
leaks...
basically bring it to operating temperature. recheck the fluid. Drive it for
a day or so and recheck the bolts.
Old Aug 16, 2013 | 05:39 PM
Mystang68's Avatar
Thanks for the advice.
Old Aug 16, 2013 | 06:59 PM
Believe me, I feel your pain.
I have a policy of oppositional bolt rotation during tightening, as well as accepting a certain amount of leaking as I gradually tighten. I think I avoid over torquing this way.
Hope you are able to figure out the cause and able to fix it.
Old Aug 19, 2013 | 12:04 AM
mustang-68's Avatar
Yea I would look at transmission lines and dip stick tube and I had a leak where the Neutral safety switch bolts to the transmission
Old Aug 27, 2013 | 01:46 PM
ChrisM's Avatar
As the others have mentioned, leaks above the pan will cause the fluid to flow down and spread around the pan. I did all the above fixes to the pan: clean, flatten, new gasket, sealant, and proper torquing. Still there was fluid leakage!
Mine was actually caused by a bad O-ring seal around the linkage shaft. I simply used a pick to remove the old one and pressed in a new ring. I also had a leak from the tailshaft and had to replace that seal as well. Now the tranny leaks no more!
But I do have a minor engine leak from the rear main seal! Oh, well.
Gill5oh
Oct 6, 2017 10:50 PM
OneCoolGT
Dec 10, 2015 07:55 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Rando
Sep 30, 2015 12:28 PM
bconboy
Sep 18, 2015 08:18 AM
