Auto to Manual
Old Dec 14, 2005 | 07:33 PM
vanisle68's Avatar
well I was thinking i would just change my car to a muanual but I have no idea what trans would be the best for the job any ideas remember its a 68 coupe with now a 351w.
Also what would be involved in the whole change and would anyone recomend doing it
Old Dec 15, 2005 | 12:06 PM
exarkun's Avatar
I have a 69 that will go under the same modification; 351W to a close ratio Tremec T56. I dont have all the details yet; probibly the one that would help is what model T56 I am going to use.
There will be some minor cutting to fit the T56 in place. To avoid cutting, you can always go with a T45 Tremec as well.
I am sure there is more that I will become aware once the car is ready for conversion. When I find out, I will place more notes here or just send me a private mesasage on here.
Old Dec 15, 2005 | 04:55 PM
montreal ponies's Avatar
Doing the same thing here, switching from an automatic to a top loader 4 speed........i've got a 351 windsor too and going with 3.50 gears in the back and locked of course...
Old Dec 15, 2005 | 04:59 PM
Doing the same thinh here, going from an automatic to a top loader 4 speed, 3.50 locked gears of course...
Old Dec 26, 2005 | 12:27 PM
tricksixtyfive's Avatar
Is there a 4 speed available for 65's that mimics an auto tranny..meaning i can shift it as well as have it run auto..like a tip tronic or something like that..
Old Dec 27, 2005 | 10:59 AM
exarkun's Avatar
Sounds like that Douglas-Nash transmission from the C4 corvettes -- if i remember it right it was a 4+3 ( 4 speed manual with a 3 speed auto overdrive ) ... but thats for that car
for a classic mustang; i doubt there is a triptonic transmission available ... its not impossible to try; such a mating of that kind of transmission and engine will run you a lot of money.
With a 289 or 302 ... I have seen a lot of 5 speeds added to them which is nice because they fit right up.
There is another possibility but I dont know anything about them; only through idle chat ... a "slam" transmission ... maybe someone here can elaberate ... but i believe that kind of transmission is really for drag racing.
Old Dec 27, 2005 | 11:15 AM
I just put a 347 in my car and i am looking for a trannny...just fishing for options, but i want a auto i can shift
Old Jan 1, 2006 | 12:56 PM
2MFF's Avatar
You could always go with a Richmond 6 speed (a TRUE 6 speed)
http://www.2mfffabshop.com/rod.htm
Old Jan 2, 2006 | 06:57 PM
exarkun's Avatar
Interesting 6 speed gear ratio - a single over drive ... interesting :scratch:
Old Jan 14, 2006 | 04:22 PM
codeman94's Avatar
what would be the estimated cost of going to a manual? say you get a transmission for around 1200-2000...how much more will it be to get all of the clutch stuff and instulation. I'm trying to decide between going to manual, or getting 4 wheel power disk brakes. whatever is cheaper is probably what I'll do.
Old Jan 17, 2006 | 10:40 AM
KGSGT350's Avatar
First of all, I would never put anything in without an overdrive if you plan on driving it on the hwys. I would go with either a T5 or Tremec depending on H/P.
I have bee quoted about 4K from Modern Driveline. Thats with a road race trans and hyd. clutch and all.
A 5 speed is also more desirable if you go to sell it
Gigantor
May 11, 2023 07:31 PM
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
