70 Mach1 Data Tag
Old Dec 12, 2006 | 07:03 PM
ARF's Avatar
ARF
Exclamation 70 Mach1 Data Tag
Im in a problem... I need to rebuild the data tag on the drivers side door of a 1970 mach1... and I dont have the data codes... Could someone help me please!?... what I need are the:
-Body Code (Mach1 fastback)
-Color Code (Grabber Orange)
-Trim Code (Mach1 interior all Black)
-Axle Code (dunno... 351 manual trany 4 speed)
-Trans Code (dunno... 351 manual trany 4 speed)
Hope 2 hear from someone soon!...
THANKS IN ADVANCE!!!
Old Dec 12, 2006 | 11:16 PM
tricksixtyfive's Avatar
http://www.mustang-blogs.com/2006/02...ford-mustangs/
all right here
Old Dec 14, 2006 | 02:51 PM
ARF's Avatar
ARF
GREAT!... got the body, color, and trim...
BUT!!... how do I get the axle and trans code?...
ANYONE?
Old Dec 14, 2006 | 05:26 PM
mtchstng's Avatar
if you have the standard wide ratio 4-speed it is code 5. if you have have a close ratio its code 6. most common is code 5.
rear end code you need to know the rear end gear ratio.
Probably a 3:25 ratio ? if it is a tracion lock that would be code R if its an open rear end its code 9. Originally there would be a metal tag close to where the driveshaft bolts up that will list the ratio.
you will also need a DSO code for the data tag. DSO=where the car was shipped to. (city) if it was originally Mexico probably in the 90-99.
hope this helps,
mitch
Old Dec 15, 2006 | 11:13 AM
ARF's Avatar
ARF
It was imported over from the states... I already figured out the DSO... now about the trans code... I think its a standar 4 speed... so it must be a code 5 then... Im gona check if it has track lock...
Old Dec 20, 2006 | 02:30 AM
CCRenegade's Avatar
Hi, why don't you get a "Marti-Report" from Kevin Marti with your VIN#?
There you can also get the correct data plates for your door.
Old Dec 20, 2006 | 04:51 PM
ARF's Avatar
ARF
didnt know about it... and how many $$$?...
Old Dec 21, 2006 | 02:37 AM
CCRenegade's Avatar
The Standard Marti Report is about 17$
The correct decals are 25 Bucks.
Website is: http://www.martiauto.com
Sep 8, 2015 10:45 AM
DarrenGT
Aug 28, 2015 10:01 AM
bigdaddy51200
Aug 20, 2015 09:25 PM
Avenger
Sep 21, 2004 02:19 PM
