'67 coupe 289 white smoke possibly blueish
I'm putting the new seals in as soon as they get here. But, let me understand this...
My compression test was normal because the leaking oil sealed it up enough to make the test look right? That's just confusing and wrong, haha.
something for you to consider .. do you know where all the rest of those little broken pieces of seals are .. they are floating around in your oil pan .. eventualy a small piece will be sucked up by your oil pump and lock it up .. then your distributor drive shaft will break and your engine will die .. if it is not a real drag pulling your oil pan i would do that sometime in the future just to clean it out and clean the oil pump screan as well ..
Curious to know if there's a magnet in the pan with shavings on it - my 69 had one and I don't know if it were done from the factory, but I cleaned them out and left the magnet in.
i think some aftermarket plugs can be had magnetic .. they used to put the round magnets in trans pans as well .. if it does`nt have one you can add one even if you have to stick it on the outside ..
Finally got around to changing the oil pan today. You were right. There were little pieces of valve seal all over inside the pan. Good information, I appreciate it.
Mike
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
