6 speed going into a 66 coupe
Im trying to find out what would I need to put a t56 6 speed behind the 347 in a coupe... has anyone gone through this already? Thanks for your help
A Man Just Needs Some....
Check out D&D transmission. Just google that. Probably will require a different bell housing. You should be able to also call them for more advise.
I did lots of research into it for doing something with my '70 transmission.
I am pretty sure you can't put a T56 in a classic Mustang without heavily modifying the frame and doing a custom transmission tunnel, and even then I don't think it would bolt up to the engine without a custom bellhousing (I am assuming your 347 is just a stroked 302 block...). The T5 5-speed, however, is pretty much a bolt-in modification.
CJ Pony Parts has a nice kit for it (with or without the transmission).
http://www.cjponyparts.com/t5-transm...1966/p/T5CK10/
http://www.cjponyparts.com/t5-transm...1966/p/T5CK15/
CiniZter
25
4/28/16 05:41 PM
