6 speed going into a 66 coupe
Old Sep 27, 2011 | 01:29 PM
t56mustang's Avatar
Im trying to find out what would I need to put a t56 6 speed behind the 347 in a coupe... has anyone gone through this already? Thanks for your help
Old Sep 27, 2011 | 03:48 PM
AlsCobra's Avatar
A Man Just Needs Some....
Check out D&D transmission. Just google that. Probably will require a different bell housing. You should be able to also call them for more advise.
Old Sep 27, 2011 | 04:00 PM
dmay65's Avatar
I'm wanting to do the same thing. The tremec magnum, try mustangs plus I think that have a jit
Old Sep 27, 2011 | 08:02 PM
Forkmachine's Avatar
I did lots of research into it for doing something with my '70 transmission.
I am pretty sure you can't put a T56 in a classic Mustang without heavily modifying the frame and doing a custom transmission tunnel, and even then I don't think it would bolt up to the engine without a custom bellhousing (I am assuming your 347 is just a stroked 302 block...). The T5 5-speed, however, is pretty much a bolt-in modification.
CJ Pony Parts has a nice kit for it (with or without the transmission).
http://www.cjponyparts.com/t5-transm...1966/p/T5CK10/
http://www.cjponyparts.com/t5-transm...1966/p/T5CK15/
CiniZter
25
Apr 28, 2016 05:41 PM
blackhawkkid308
1994-2004 V-8
18
Dec 22, 2015 03:17 AM
