289 heads
Old Jan 26, 2011 | 01:10 PM
Kerry's66's Avatar
289 heads
I need help understanding the difference between a 289 and 289 hipo
Old Jan 26, 2011 | 01:13 PM
HOSS429's Avatar
legacy Tms Member
hi perf heads have a raised area around the valve seat area as well as they will have screw in studs .. there may be more .. for some reason my picture didn`t come thru .. google up hi performance 289 heads and you can see some
Old Jan 26, 2011 | 01:51 PM
Kerry's66's Avatar
Surely the extra horsepower doesn't come from screw in studs and springpockets. There has got to be more
Old Jan 26, 2011 | 02:29 PM
HOSS429's Avatar
legacy Tms Member
i think the valves and ports are the same .. the valve pockets and screw in studs promote higher rpm`s from the solid cammed motor
Old Jan 26, 2011 | 02:43 PM
Kerry's66's Avatar
If you run the same cam, carb, intake, etc., shouldn't the non hipo heads perform the same
Old Jan 26, 2011 | 05:36 PM
HOSS429's Avatar
legacy Tms Member
that is true .. hi po 289`s had steel cranks .. stronger rods with 3/8 ths rod bolts .. a much thicker harmonic balancer .. revved a bit higher due to a solid lift cam so the heads had to be a bit beafier .. not nescessarily better breathing..
Old Feb 3, 2011 | 10:18 PM
sixty6fastback's Avatar
I have a set of freshly rebuilt 289 HiPo heads. They have been ported & port matched. Also they have larger Chevrolet valves installed. Needless to say the motor runs pretty healthy! Google "289 HiPo" and you can get a lot of info. I have a documented full roller HiPo motor. She runs about 400hp!!!!
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
Mustang65bob
Sep 21, 2015 11:30 AM
earl610
Sep 7, 2015 11:57 AM
