1966 Mustang Suspension Bottoming out?
Old Oct 14, 2013 | 06:43 PM
Blackmagic's Avatar
I have a 1966 Mustang Coupe and when I hit a fairly large bump it "bottoms out", makes a clanking noise like it is dragging bottom but it is not hitting the ground. Have any of you had this problem and what is the soluation?
Old Oct 14, 2013 | 08:33 PM
AzPete's Avatar
Check all of your suspension parts and make sure everything is tight. Check the tail pipes and entire exhaust too.
Old Oct 15, 2013 | 06:24 AM
maybe time for some new shocks and springs
Old Oct 15, 2013 | 04:31 PM
matcox83's Avatar
Can you tell if it's front or rear? You have no scrapes on the bottom of the car? You might have worn out bushings in the front, rear, or both. There are bump stops in front and rear, are they in place?
Old Aug 18, 2023 | 09:16 AM
Monster_mustang626's Avatar
65 mustang
Can anyone help my 65 mustang front driver side fender bottoms out and rubs against my tire when I hit a bump any ideas of what exactly it could be I was thinking the shock but im not sure
Old Aug 18, 2023 | 09:38 AM
05stangkc's Avatar
Welcome,
Some Side Shots of Both Front Wheels Facing Straight Ahead would Be a Good Start. After That Some Shots of the Suspension With Wheel Removed Will Likely Be Needed to Come Up With a Good answer!
Mgb,
KC
Old Aug 18, 2023 | 09:41 AM
Welcome,
Mgb,
KC
will do just as soon as I can thank you
Driver side and it sits 1/2 inch lower then the passenger side
Passenger side
will send a picture like that when I can thank you for all the help so far
Old Aug 18, 2023 | 01:25 PM
05stangkc's Avatar
My Best Guess So Far is a Bad Spring or Spring Perch & Possibly a Damaged or Missing Stop.
Look At Part Directly Below Spring and Rubber Stop at Top on The Spring Cover.
Also Tires & Rim Width Maybe a Bit Too Large For Safe Clearance in all Situations. Even After Repair.
Are Those 15x6 or 15x7 Wheels Do you Know?
Curious as To What You Find When Wheel is Pulled.
Anyhoo My Best Guess So Far!
A Pic Exactly as I Posted of Your Car May Tell the Tale!
Mgb,
KC
Old Aug 18, 2023 | 01:33 PM
Mgb,
KC
will send a picture like this when I can
Old Aug 18, 2023 | 01:38 PM
05stangkc's Avatar
I Check in From Time To Time! We Will See What We Can Figure Out!
You Are Welcome For the Help.
Your Suspension and Wheelhouse are Very Similar to My Daughters 67 Fairlane Which I Have Worked on Many Times and Have Replaced Spring Seats on Myself. So I Got a Good Feel For What You Are Working On!
Mgb,
KC
Old Aug 19, 2023 | 01:11 PM
Mgb,
KC
Old Aug 19, 2023 | 01:52 PM
05stangkc's Avatar
Oh My Goodness!
From What I Can See at the Very Least The Spring Saddles are Shot. They Should Be Replaced. The Aftermarket Have Some With Bearings instead of Rubber Bushings Which Last Longer & Make The Car Handle Better. Just an FYI. You Can Use a Good Quality Rubber Style Of Course! Looks Like Upper Ball Joint Maybe Bad as Well. This is a Partial to Answer Question of Vehicle Being Lower on One Side. Also The Wheel Traveling Father Up Than Normal. I'm Surprised the Limiter Stopper is intact. Your Wheel & Tire Size Are At the Limit Likely and with worn Pieces and Things Moving Around You Got the Damage. Even Wheel Alignment Can Change Clearances when Things are At the Limit! Oh And Height Can Also Be Due to Missing or Worn Out Spring Insulator as Shown In First Link Below!
The Daughters Fairlane is Using a 14x6 Ford Magnum 500 With a P205/70/14 and Required a 1/4 Spacer So the Tire Would Not Contact the Upper Control Arm When Topped Out Like When The Car was Jacked Up The Middle of the Tire Sidewall Would Be Cut . Say if you Went over a Bridge Fast and The Front End Came up! Just Happened to Catch That Issue While Under The Car Working on it. On Stands the Wheel Turned Fine But on the Jack They Rubbed. Also We Had to remove Wheel Opening Moulding For Clearance as it would Rub Tire on Turns. You Have to Allow for Wheel Travel When Turning as well When Using a Larger Wheel & Tire Combo!
Now From this Picture if it Were My Car I Would Pressure Wash The Entire Under Carriage & Inspect Everything. Looks Like a Lot of Miles have Passed since this Car Has Had Attention Underneath. I Would Be Concerned With All Suspension Pieces and All Braking Items Including Steel & Rubber Lines. It's Just a Matter of Time Before a Failure Which Could be Deadly. I Know it's a Spendy Job and The Old Ram Style Power Steering Loves to Leak Fluid all over the Suspension and Turn The Pieces To Goo! Hate To Be The Bearer of Bad News But Don't Want to See anybody get Hurt! I Know after an Cleaning and Inspection More Items Will Be Found Bad. I Would Compare Spring Height When Saddles are Replaced and if Not Equal Front Springs should Be Replaced! Shocks Maybe Ok and BTW on these Old Style Shocks They Strictly Dampen the Ride And Do Not Effect Ride Height. I Put KONI Shocks All around on the Fairlane & Like Em as an FYI!
BTMO
Mgb,
KC
Also Notice Spring Insulator in this Kit!
https://www.ebay.com/itm/12182421119...Bk9SR8y_tPbBYg
This Kind of Kit Would Be a Good Start!
https://www.ebay.com/itm/37376226832...Bk9SR9T-nvbBYg
FYI Bearing Style Saddles
https://www.topflightautomotive.com/...CABEgIht_D_BwE
OK THROUGH EDITING!
Will3212
24
Mar 27, 2013 11:21 PM
jamesdem1123
Dec 30, 2008 09:51 PM
SINBUSTER007
Oct 20, 2008 07:49 PM
thecarguy
Feb 10, 2007 09:32 PM
mbradsha75
Feb 25, 2005 09:03 AM
