Sounds like a haunted house door under the rear of my car!
Old Feb 9, 2007 | 10:13 AM
thecarguy's Avatar
Unhappy Sounds like a haunted house door under the rear of my car!
This is honestly getting old, as it seems every other week I am posting about some noise. A couple weeks ago I figured out my clunk sound coming from the suspension - loose bolt on front swaybar mount that bolts to chassis. NOW, I have a noise that is getting progressively worse from the rear.
The best I can describe it is it sounds like a really old haunted house door slowly opening. It's that type of a creak sound. I'm assuming it is the rear suspension as the exhaust mounts all seem fine. It does get worse as the car is driven longer - not sure if it has to do with heat or not.
Only mods I have are Eibach Pro-Kit springs and Tokico D-Spec shocks. The swaybar is factory. One guy told me to spray a little lube on the swaybar bushings - I did this and they are not it. When I fold the rear seats down the noise is almost unbearable.
Any ideas?? I re-checked the torque on all bolts from the suspension install and it's all good.
Old Feb 9, 2007 | 11:47 AM
theedge67's Avatar
Does it only make noise when you hit a bump, go around a corner, or is it a constant creaking?
Old Feb 9, 2007 | 12:15 PM
Couper93's Avatar
I got the same thing.
Sounds like its in the DS seat or under one of the seats in the rear.
Also my lumbar support quite working, I wonder if it is something loose in that.....
Old Feb 9, 2007 | 12:19 PM
freebass55's Avatar
Do you have your spare still in the trunk? Check and see if something is loose in there. Other than that, I would know without being there.
Old Feb 9, 2007 | 01:13 PM
thecarguy's Avatar
To answer a couple questions...
It does it real loud when doing a hard left turn, when angling into a driveway slowly and does it a little quieter when hitting small regular bumps and imperfections crusiing straight down the road.
I did check the spare and everything is solid. Does not seem to be associated with the spare.
Old Feb 9, 2007 | 01:27 PM
Couper93's Avatar
My spare is locked down tight.
I typically crank the radio so I cannot hear it.
I will pay attention.
I also have the 'singing' rearend.
Old Feb 9, 2007 | 01:29 PM
traffic142's Avatar
I think there is a TSB on this......something about the clutch in the rear axel going out? not sure though
Old Feb 9, 2007 | 01:31 PM
Giddyup's Avatar
Does it happen regardless of type of weather (warm or cold days, rainy, etc.)? I get all kinds of creaks, but when the weather is warmer they seem to be non-existent.
Old Feb 9, 2007 | 05:44 PM
thecarguy's Avatar
So far the weather has been a little on the cool side. This has been going on for the past couple weeks. It does get worse the longer I drive the car. 1st thing in the morning it is quite.
Old Feb 9, 2007 | 07:04 PM
DynamicmustangGT's Avatar
One word WARRANTY....use it while its still good and it costs you nothing. Bring it in!
Old Feb 9, 2007 | 09:17 PM
drakino's Avatar
TSB 06-19-2 PDF Doc here
Should be covered under warranty. Had the work done on mine in December, and the noise is completely gone now.
Old Feb 10, 2007 | 09:32 PM
Burke0011's Avatar
Big Falken Tires
Exactly -its a TSB issue..... I need to have this taken care of myself....
Ecostang
Nov 3, 2022 08:50 PM
lakersfreak
Aug 12, 2015 01:52 PM
redneb
Aug 10, 2015 12:25 PM
chadh92
Jul 29, 2015 06:56 AM
awoychosky123
Jul 21, 2015 11:12 AM
