5th gear grinding noise and vibrations HELP
Old 4/9/16, 08:44 AM
AS15's Avatar
I have a 96 gt and when I'm on 5th gear there's lots of grinding noises and when I'm doing 80 or more there's lots of vibrations. What do you guys think?
Old 4/17/16, 05:20 PM
Don 123's Avatar
Have it rebuilt or try a junkyard.
Old 4/17/16, 05:28 PM
AS15's Avatar
But what do you think the problem is? It was already rebuilt 10000mi ago
Old 4/18/16, 10:28 PM
AS15's Avatar
SOLVED
If anyone is interested the problem.was a bad U-joint and bearings. All good now
PDOGG74 (5/4/16)
Old 5/4/16, 11:15 AM
PDOGG74's Avatar
thanks, I care what you put in may help someone who is not a member or someone like me that is browsing and may have a similar problem down the road. I will put this bit of info in the far reaches of my mind if I come across a problem of the same nature later on.
Old 8/31/16, 07:03 PM
FIAMystic's Avatar
Do you do the work and if so how much did it run you either way?
iceD
4/20/16 07:46 AM
Tracy Warner
4/10/16 05:35 PM
cristen
4/1/16 11:40 AM
Quick Reply: 5th gear grinding noise and vibrations HELP
