5th gear grinding noise and vibrations HELP
Old Apr 9, 2016 | 08:44 AM
AS15's Avatar
I have a 96 gt and when I'm on 5th gear there's lots of grinding noises and when I'm doing 80 or more there's lots of vibrations. What do you guys think?
Old Apr 17, 2016 | 05:20 PM
Don 123's Avatar
Have it rebuilt or try a junkyard.
Old Apr 17, 2016 | 05:28 PM
AS15's Avatar
But what do you think the problem is? It was already rebuilt 10000mi ago
Old Apr 18, 2016 | 10:28 PM
AS15's Avatar
SOLVED
If anyone is interested the problem.was a bad U-joint and bearings. All good now
Old May 4, 2016 | 11:15 AM
PDOGG74's Avatar
thanks, I care what you put in may help someone who is not a member or someone like me that is browsing and may have a similar problem down the road. I will put this bit of info in the far reaches of my mind if I come across a problem of the same nature later on.
Old Aug 31, 2016 | 07:03 PM
FIAMystic's Avatar
Do you do the work and if so how much did it run you either way?
iceD
Apr 20, 2016 07:46 AM
Tracy Warner
Apr 10, 2016 05:35 PM
cristen
Apr 1, 2016 11:40 AM
