Catalytic Converter Issues
Old 7/25/16, 11:39 AM
CGordini's Avatar
Hey all,
2007 Ford Mustang V6 Pony Package + Ford Racing Dual Exhaust.
About two months ago (!) I attempted changing my spark plugs (and wires, and distributor coil). In the process of doing so, I cracked the (new) plug, causing a misfire in Cyl 2. Had no idea what it was, just noticed at low RPM's I didn't have as much get-up-and-go. Didn't know it was in Cyl 2, so I took apart 4, 5, and 6, rebuilt them with new plugs, tried again, no difference, so I said eff it and took it to a mechanic.
Hence, now knowing that Cyl 2 was the one that cracked. In the process of which, I probably put >50mi on a misfiring cylinder.
Ever since then, I've had the (dreaded) P0420 "Catalyst System Efficiency Below Threshold (Bank 1)". For the most part, I've ignored it -- it wasn't really hurting anything and as far as I know the "right answer" is either A) a new O2 sensor, or B) a new Catalytic Converter (which would make sense due to putting 50mi on a misfiring cylinder).
Took my Pony to a track day this weekend, and it sure sounds like I blew a hole through my exhaust now. Really hoping I didn't scrap my muffler(s).
I've clearly put off fixing this properly for far too long.
I don't REALLY want to drop $1k per cat for an OEM replacement from Ford.
American Muscle has a few alts listed from Pypes, and O'Reilly/AutoZone/etc have FloMaster and Magnaflow.
As far as I can tell, Magnaflow is the cheap answer (I'll still have to deal with cutting and welding, which I have to do anyway due to this (theoretical) hole in my exhaust).
tl;dr Any recommendations for a replacement catalytic converter? Also, do I need two, or just one? I think two -- one per bank.
Thanks!
Old 12/5/16, 03:17 PM
GermanPetrolhead's Avatar
Any solution on this?
A magnaflow metal cat (200 cells) or ceramic cat (400 cells) sounds quite attractive.
But i've been told that once you change, you have to change both.
Old 12/6/16, 11:35 AM
CGordini's Avatar
Ended up buying an entire cat assembly off RockAuto for ~$270 and having the old one cut off -- something worth noting is I have a V6 with an X-pipe, so they had to do some custom work there.
I originally had bought a pair of universal Magnaflows, but it would have been *more* expensive to adapt those in, than just replacing with a factory cat assembly.
Old 12/6/16, 01:46 PM
Yeah but I guess for the 2013 V6 models I don't find such whole assembly.
Only a Davico part but I guess its a universal catalytic converter which you have adapt:
http://www.rockauto.com/de/catalog/f...converter,5808
Old 12/7/16, 01:39 PM
I guess this one will make it:
http://www.ebay.com/itm/191984143359
05Mustangfan
8/25/16 08:20 PM
killaz05
2/18/16 02:46 PM
TMSBrad
Announcements
4/5/05 06:28 PM
f1-cobra
4/9/04 11:54 AM
Quick Reply: Catalytic Converter Issues
