Eduardo's 94 Mustang GT thread
Old 12/22/14, 01:54 PM
  #521
Legacy TMS Member Pr
edumspeed's Avatar
Clean and with a nice coat of paint
Still need 99-04 brake pads. A pitty that the 94 spec ones are like new
Old 12/22/14, 01:56 PM
  #522
Nice. Always easier when they're off the car!
Old 12/22/14, 01:59 PM
  #523
edumspeed's Avatar
Found a pic on an article about the swap on where the spindle needs to be grinded for the calipers to fit. Red line where there's interference and blue line the material to be cut.
Old 12/22/14, 02:00 PM
  #524
edumspeed's Avatar
Ya. Too bad the rears are still in the car lol.
Old 8/27/15, 10:40 PM
  #525
edumspeed's Avatar
update
Ordered a head gasket set because most probably one of the head gaskets was incorrectly installed and is causing the weird symptoms the motor has. And also I scored this:
Old 8/29/15, 12:27 PM
  #526
Location: That town you drive through to get to Myrtle Beach
nice score!
Old 8/31/15, 02:20 PM
  #527
edumspeed's Avatar
nice score!
Yeah. I couldn't believe myself. Asking price was $80 and I made a $50 offer for kicks and the guy accepted it
Old 8/31/15, 02:22 PM
  #528
edumspeed's Avatar
Gaskets and arp ultra torque lube arrived today. Teardown begins tomorrow
Old 9/1/15, 03:02 PM
  #529
edumspeed's Avatar
I made some good progress today. Just need to remove the headers and valve covers to unbolt the heads off the block. Then the long proces of cleaning the mating surfaces an re-assemble everything back.
Old 9/1/15, 03:13 PM
  #530
edumspeed's Avatar
side note:
Driver's side caliper is bad. Wheel gets locked
Old 9/2/15, 09:46 AM
  #531
edumspeed's Avatar
Driver's side head is out.
Old 9/2/15, 09:57 AM
  #532
edumspeed's Avatar
This is a rough idea of how I want the car to look in the long run.
Old 9/2/15, 12:36 PM
  #533
edumspeed's Avatar
Found the cause of the cooling & pinging issues
Old 9/4/15, 05:10 PM
  #534
edumspeed's Avatar
Cylinder heads and rockers are installed. I also got rid of the thermactor tubes that were doing nothing. I just cut the metal tubes from the junctions on the heads and flipped them. And for sealing them, i used a section from the discarded head gaskets
It's a shame I'm broke atm so I couldn't replace them with roller rockers
Old 9/8/15, 06:29 PM
  #535
Jim74656's Avatar
is that a garret turbo??? would love to see the numbers on it!
Old 9/26/15, 10:22 PM
  #536
edumspeed's Avatar
Seller never shipped it. I oppened a case and was given a refund.
Old 9/26/15, 10:27 PM
  #537
edumspeed's Avatar
Update
Fired up the engine. There's white smoke and an oily residue from the passenger side exhaust (where the gasket was installed incorrectly) and isn't idling right. Pretty frustrated right now.
And the shift kit arrived today.
Old 10/12/15, 08:17 AM
  #538
edumspeed's Avatar
I went at the car again and figured out the unsteady idle it had. The vacum hose junction below the alternator was unhooked and the egr and fpr hoses were mixed up. Now it purrs like a big kitten lol. The oil getting off the passenger tailpipe is still an issue, but since I put 5w30 oil in the crankcase and the piston rings must have suffered a bit for the head gasket issue must be going past them. I'll just put 20w50 oil as it had that on the begining.
Old 10/13/15, 12:01 PM
  #539
Needs to be more Astony
Knight's Avatar
Sweet.
Old 10/20/15, 08:08 AM
  #540
Former Vendor
Chad@Amp'D's Avatar
Nice
edumspeed (4/30/16)
Quick Reply: Eduardo's 94 Mustang GT thread
