Door handle rattles...FIXED!!
Old Nov 10, 2007 | 12:38 PM
Cavero's Avatar
I know I'm not the only one to have this problem...so I'm glad to spread word of the solution! Today I finally found that **** rattle in the area of the driver's side interior door handle and I found something very peculiar. As it turns out, the door handle cover isn't one piece like I thought it was. You have the main bezel around it, but then there's actually a backplate as shown here:
When I looked closer I realized that the back plate was very loose (animated gif):
Attachment 35394
So I removed it used some double sided foam tape like this:
And problem solved! No more rattles! Now while I was in there I removed the shift lever boot and added some tape to get rid of that rattle:
And then the same to the A-pillar. Now when I had the A-pillar off I found this. Does anyone have any idea what this is?
Old Nov 10, 2007 | 02:05 PM
TcodeV8's Avatar
thanks for the post & pictures! I have the same A-pillar rattle/squeak, as well as the shifter rubbing that I want to take care of once and for all (was actually considering buying a new boot for it)
Old Nov 10, 2007 | 02:51 PM
ShowGT's Avatar
As for the spacer you showed above, I have one in my toolbox as well. Never been an issue but I did use some leftover moleskin on the access panel behind the handles.
Old Feb 21, 2008 | 01:48 PM
metroplex's Avatar
Subscribed!
Old Feb 21, 2008 | 04:44 PM
jskibisky's Avatar
I have that same rattle... started up when the weather got cold. What is the correct method for removing the backplate (I don't want to break anything) ? Thanks !!
Old Feb 21, 2008 | 04:55 PM
jeffgall's Avatar
Dido. Mine started rattling too this year when the weather got cold. How did you remove the back plate without breaking it?
Old Feb 21, 2008 | 06:30 PM
GTMark052's Avatar
Has anyone gotten any rattles in the rear passenger area behind the doors?
Old Feb 22, 2008 | 10:16 AM
BEW119's Avatar
TMS Legacy Member
Remove the back plate with a small flat screwdriver, apply pressure near the handle mechanism and it pops off. Used self adhesive felt to stop the rattle.
Old Feb 22, 2008 | 01:44 PM
Cavero's Avatar
Ditto. Prying in the area by the handle pivot gives you the most space to work with and if you marr the plastic you'll never see it. Just be careful because the plastic is somewhat soft.
Old Feb 23, 2008 | 12:14 AM
cmplxlgc's Avatar
this thread is god! The rattle (in both doors) have been drivin me nuts for weeks.......
Old Feb 23, 2008 | 08:38 AM
carnutny's Avatar
I just did the mod on the doors and it took all of 5 minutes, Thank you!!
Old Feb 26, 2008 | 07:54 PM
molo's Avatar
T H A N K Y O U ! ! !
Old Feb 26, 2008 | 09:27 PM
JonCo's Avatar
Thanks, these 20" rims aren't the most forgiving. I should almost be rattle free!
Old Feb 27, 2008 | 05:08 AM
Emu Hunter's Avatar
Old Mar 2, 2008 | 10:56 AM
davisinla's Avatar
My hat's off to you too...just did "the door fix" with some of those little stick-on felt pads (the kind used on the bottom of flower vases that protects the furniture).
Old Apr 19, 2014 | 10:18 AM
John SCB's Avatar
Search feature for "door handle rattle" brought this thread up. Problem fixed. Thanks OP!
Old Apr 19, 2014 | 03:07 PM
Lime GT's Avatar
Wow, an oldie but a goodie...
Old Apr 23, 2015 | 03:00 PM
My_Wifes_Pony's Avatar
This thread is gold. Goodbye rattle!
Old Apr 23, 2015 | 06:46 PM
houtex's Avatar
Yay resurrected thread!
So anyway, I used a square of velcro on the back, centered, and that shut mine up. Both those, and the ones down in the grab handle area.
Now, as to the unanswered question of the golden square thingy in the A-pillar cover? That's a box that happens to, yep, grab onto some velcro... er, hook and loop... that's on the pillar, thereby providing a mid anchor in addition to the big hooks on the dash and the clips higher up.
NC14GT
Sep 10, 2017 04:47 PM
RCooke08GT
Feb 19, 2017 03:03 AM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
