Pricing Announced For Aluminator XS Crate Engine
By -
Article courtesy of MustangsDaily.com, your source for all the latest Ford Mustang news and articles.
M-6007-A50XS
Ford Racing initially revealed the Aluminator XS crate engine back in December at the PRI Show in Florida, a 500 horsepower motor that utilizes the same technology and hardware that went into the naturally aspirated V8 found in the 2013-2014 Mustang Cobra Jet. Now Ford Racing has released more details about the crate engine including pricing.
Each Aluminator XS crate engine is hand-assembled by the same technicians that build the Cobra Jet race motors and feature many of the same premium parts like Manley H-beam connecting rods, ARP rod bolts, Mahle forged pistons, CJ short runner-high RPM intake manifold, 1517 CFM dual 65mm CJ Throttle Body, Competition High RPM pulse ring and 12 quart competition oil pan. Suggested retail pricing for the engine, part number M-6007-A50XS, is listed at $15,995.00.
Ford Racing Aluminator XS Crate Engine Specs:
5.0L – 302 cubic inches
11.01 compression ratio (nominal)
Mahle hard anodized forged pistons with Graphal low friction coating
Manley H-beam connecting rods with ARP2000 bolts
Production aluminum cylinder block features cross-bolted main bearing caps and think main bearing bulkheads for bottom-end strength
Ford Racing camshafts
M-6550-M50BINT intake camshaft – 13mm lift / 263 degrees duration
M-6550-M50BEXH exhaust camshaft – 13mm lift / 290 degrees duration
Ford Racing M-6675-M50BR 12 quart rear sump oil pan features optimized oil drain back and windage tray to control oil and improve high-rpm performance
Ford Racing M-6600-50CJ high performance billet steel gerotor oil pump
Ford Racing M-9424-M50CJ Cobra Jet tuned intake
Ford Racing M-9926-CJ65 throttle body
Ford Racing M-9593-LU47 47 lb fuel injectors
Four-valve-per-cylinder Boss fully CNC ported aluminum heads
Roller-finger camshaft followers
Ford Racing M-6513-M50BR Boss valve springs
Ford Racing M-12A227-CJ13 high RPM pulse ring
Ford Racing M-8600-M50BALT alternator and mount
Ford Racing M-6P057-M50B blue coil covers
Ford Racing M-12405-M50 heat range 0 spark plugs
Ford Racing M-6731-FL820 oil filter
