Help New clutch safety switch not working
Old May 23, 2026 | 12:32 PM
Spider007's Avatar
Hi Just got this car needed to have the clutch safety switch replaced, I replaced it now it will not start. I noticed this plastic thing looks like some type of connector or ? Where does it go and is it the reason for a no start. It is attached to the safety switch wiring ..Thanks !!!
Old May 23, 2026 | 06:35 PM
shaneyusa's Avatar
Post a picture of what you are seeing. the switch thinks the clutch is not pressed…. Could be it is not connected correctly, if at all, or it is defective. If i remember correctly it has a button like trigger that hits a plate when you push in the Clutch. That should close the circuit that allows the car to crank.
Old Yesterday | 01:29 AM
rocknrod's Avatar
Clean Machine Supercharged S-197 Member
First crawl under there and pull the plunger on the switch out. If that doesnt work you "may" have a bad switch.
wwwii63
Jun 17, 2023 01:10 AM
Len
GT Performance Mods
Feb 2, 2010 08:16 AM
markush
1994-2004 V-8
Sep 14, 2007 10:23 PM
BatNastard
V6 Performance Mods
Sep 24, 2005 06:14 AM
