2010 Ford Mustang Automatic Transmission Solenoid Pigtail Wire Harness Diagram
Hello , does anyone have the schematics diagram of the wiring harness colour codes …where each colored wire goes to attach to a new harness wires..
Do not know which color goes where withbthe new harness….
Ford does not have this they say…any help will be greatly appreciated..
thank you
Updated Title For Better Web Search
Kc Admin 09/20/2024
thank you
Kc Admin 09/20/2024
The Analog Admin!
Received 3,187 Likes
@Mustang Flyer
Whoever Told You That Does Not Know How To Pull Up a Shop Manual!
Here You Go Out of Current FORD Dealer Data Base Shop Manual!
If I Missed Anything You Need, Reference Number in Illustration and I Will get It For You!
This Is Out of Your Other Thread Which is a Duplicate So I Will Remove it.
{My transmission harness broke while changing solenoid..Does anyone have a wiring harness schematics ,, colors of where each wire goes…
bought a new harness off amazon but wires not matching…does anyone have a diagram of wiring ..}
I Assume You Mean a Repair Pigtail Not a Complete Harness????
Now Realize if Repair Pigtail Has Different Colors You Will Have To Make Your Own Cross Reference From Pin Positions on Diagram.
Ford dies not have this they say…any help will be greatly appreciated..
thank you
thank you
Mustang Flyer (9/19/24)
What was the reason for deleting my post to the OP, as I was attempting to provide him the link for the repair and service help forum section...
Pigtail is problem
@Mustang Flyer
You are a life saver ..thank you so much
stopped at a transmission place could not help
this seems to be it 2010 ford mustang 4.0 litre thanks
05stangkc (9/19/24)
The Analog Admin!
Since I Was Providing His Information in Correct Section Thread, First Thread Was Duplicate & Not Needed. Your Post is Still in Thread But in Graveyard! I Did Mention in My First Post That He Had Duplicate Thread. It Was a Later Edit. You May Have Missed it!
Kc
The Analog Admin!
You Are Welcome!
Did Not Mean To Sound So Harsh About FORD Not Having The Information But I Spent 30+ Years at Ford Dealerships and Many Many Customers Would Come in For Help & Say Some Other Dealer Could Not Help Out With These Kind of Things and it Was Usually Just Dealer Laziness! Just Brought Out Some Old Frustrations!
Best of Luck With The Repair!
Kc
Kc
Okay, thanks for clarifying... I didn't even know that he created another thread in the repair section, as I was also just as confused...LOL
05stangkc (9/19/24)
The Analog Admin!
Make Sense? I'm No Electrician By Any Means But Common Sense Would Dictate They Simply Need to Go From The Same Place on old Plug To New Plug.
On Position 5 & 12 on Old Plug You Are Supposed to Have Green & White Wires.
Looks Like a Bunch of Green & White Wires Tie Together Other Side of The #12 Wire. The 29-2 on Last Wiring PDF Post 2 on First Post Rolls To 29-1 on This PDF Post 9.
Kc
05stangkc (9/19/24)
The Analog Admin!
I Try, Be Advised I Tend To Edit My Help Posts a Lot So Always Reread The Help Post if Still Working The Problem as I May Have Updated.
You Got This!
You Got This!
