2010 Ford Mustang Automatic Transmission Solenoid Pigtail Wire Harness Diagram
Old Sep 19, 2024 | 03:03 PM
Mustang Flyer's Avatar
2010 Mustang Member
Hello , does anyone have the schematics diagram of the wiring harness colour codes …where each colored wire goes to attach to a new harness wires..
Do not know which color goes where withbthe new harness….
Ford does not have this they say…any help will be greatly appreciated..
thank you
Updated Title For Better Web Search
Kc Admin 09/20/2024
Old Sep 19, 2024 | 03:12 PM
05stangkc's Avatar
@Mustang Flyer
Ford dies not have this they say…any help will be greatly appreciated..
thank you
Whoever Told You That Does Not Know How To Pull Up a Shop Manual!
Here You Go Out of Current FORD Dealer Data Base Shop Manual!
If I Missed Anything You Need, Reference Number in Illustration and I Will get It For You!
This Is Out of Your Other Thread Which is a Duplicate So I Will Remove it.
{My transmission harness broke while changing solenoid..Does anyone have a wiring harness schematics ,, colors of where each wire goes…
bought a new harness off amazon but wires not matching…does anyone have a diagram of wiring ..}
I Assume You Mean a Repair Pigtail Not a Complete Harness????
KC
Now Realize if Repair Pigtail Has Different Colors You Will Have To Make Your Own Cross Reference From Pin Positions on Diagram.
Old Sep 19, 2024 | 03:34 PM
m05fastbackGT's Avatar
What was the reason for deleting my post to the OP, as I was attempting to provide him the link for the repair and service help forum section...
Old Sep 19, 2024 | 03:35 PM
2010 Mustang Member
Pigtail is problem
@Mustang Flyer
You are a life saver ..thank you so much
stopped at a transmission place could not help
this seems to be it 2010 ford mustang 4.0 litre thanks
KC
thanks so much
Old Sep 19, 2024 | 03:39 PM
05stangkc's Avatar
I Think He Took That as Create a New Thread, Which He Did in The Repair Section. So Your Post is in The First Thread is in The 2010-2014 Section. It Confused Me at First as Well as The Question Was a Bit Different.
Since I Was Providing His Information in Correct Section Thread, First Thread Was Duplicate & Not Needed. Your Post is Still in Thread But in Graveyard! I Did Mention in My First Post That He Had Duplicate Thread. It Was a Later Edit. You May Have Missed it!
Kc
Old Sep 19, 2024 | 03:48 PM
05stangkc's Avatar
thanks so much
You Are Welcome!
Did Not Mean To Sound So Harsh About FORD Not Having The Information But I Spent 30+ Years at Ford Dealerships and Many Many Customers Would Come in For Help & Say Some Other Dealer Could Not Help Out With These Kind of Things and it Was Usually Just Dealer Laziness! Just Brought Out Some Old Frustrations!
Best of Luck With The Repair!
Kc
Old Sep 19, 2024 | 03:51 PM
Okay, thanks for clarifying... I didn't even know that he created another thread in the repair section, as I was also just as confused...LOL
Old Sep 19, 2024 | 05:34 PM
2010 Mustang Member
I only have one ?…in the ford diagram there is
2 ..GN-WH wires..? As long as it is matched up is it fine to either or same new wires
thanks
Old Sep 19, 2024 | 06:08 PM
05stangkc's Avatar
thanks
It Looks as You Should Have 11 Active Wires. I Would Save Those Two For Last {But Positioning is Everything}. Also See Last PDF Where it Shows Pin Numbers on Plug on Left Side.
Make Sense? I'm No Electrician By Any Means But Common Sense Would Dictate They Simply Need to Go From The Same Place on old Plug To New Plug.
On Position 5 & 12 on Old Plug You Are Supposed to Have Green & White Wires.
Looks Like a Bunch of Green & White Wires Tie Together Other Side of The #12 Wire. The 29-2 on Last Wiring PDF Post 2 on First Post Rolls To 29-1 on This PDF Post 9.
Kc
File Type: pdf
Old Sep 19, 2024 | 06:14 PM
2010 Mustang Member
Great thank you
Helps alot
Old Sep 19, 2024 | 06:47 PM
05stangkc's Avatar
I Try, Be Advised I Tend To Edit My Help Posts a Lot So Always Reread The Help Post if Still Working The Problem as I May Have Updated.
You Got This!
KC
Old Sep 19, 2024 | 06:49 PM
2010 Mustang Member
Got it
Old Sep 27, 2024 | 05:34 PM
2010 Mustang Member
P0745 code is gone with new solenoid assemble
So original code is gone,,,installed harness found from same mustang in junk yard …
now getting code P0743, PO750, Po755, PO760
question is this due to wrongly wiring the harness pigtail plug and if so is the harness ok or should i use a new one with all different colors and take chance in rewiring..
i basically took a pigtail harness off a 2010 mustang and rewired it with matching colors of my 2010 mustang and all mayched except 2 same took a guess …do you think i wired something wrong ..used shrink wrap single connectors
will try
to take a stab at it one more time
should i just take it to transmission shop or is a mechanic shop ok..
thanks
Old Sep 27, 2024 | 08:02 PM
05stangkc's Avatar
Here is Some More Shop Manual Pdf's For Issue!
All it Takes is One Wire out of Place.
KC
File Type: pdf
Old Sep 27, 2024 | 08:06 PM
2010 Mustang Member
Great thankyiu
This will help thanks
Old Sep 28, 2024 | 02:48 PM
05stangkc's Avatar
Added Pdf to Post 14
Also Upgraded Avatar & Title
KC
Old Sep 28, 2024 | 04:49 PM
2010 Mustang Member
Thank you
sosocrates
Nov 10, 2021 04:56 PM
Louie
05-09 Interior and Audio Mods
Nov 28, 2007 06:55 PM
CJ428
Sep 27, 2005 06:48 PM
mstngchef
Jun 10, 2005 10:07 PM
