Clicking sound from rear
Old Today, 11:00 AM
TMS Denmark S-197 Fan
Eliminator.dk's Avatar
Hi.
I have a annoying click sound from car rear end. It has been there for about 4 years now, but decided to do something now. ( not more , and not less over the years )
Don`t feel it follows the wheel rotation. It`s a little faster. . . I can only hear it when I pass between buildings or hard fence by low speed.
Things that have been checked :
1.) stones or other pieces in tires.
2.) loose brakepads or shims.
3.) things close to the wheels.
4.) no sound on a lift with rotating wheels.
5.) no sound on a lift with rotating wheels and brakes slightly activated.
6.) wheel bearings feels good, and again it follow obvious not the wheel rotation.
Mustang GT , 2005
Looking forward to hear, if anyone recognizes the problem .
small video attached.
Thanks for looking
File Type: mov
Old Today, 11:03 AM
The Analog Admin!
05stangkc's Avatar
Received 2,983 Likes on 2,193 Posts
Some Idea's Here My Friend!
Not Seeing Your
Vid!
Pdf, Has Some Fun Terms To Ponder!
https://themustangsource.com/forums/...p-link-550939/
Kc
File Type: pdf
Eliminator.dk (Today)
Old Today, 12:27 PM
The Analog Admin!
05stangkc's Avatar
Instead of on Lift Might Try Your Tests With Rear Wheels on Jackstands So Suspension is Loaded.
Vid To Me Sounds Like Maybe Driveshaft.
Just another Process of Elimination.
On a Side Note I Found an Exhaust Leak I Did not Know I Had With The In Between Echo on a Tight Street! Can Be a Handy Tool!
Old Today, 12:46 PM
Hi. Yes , something with the shaft probably ???
CV joint or something.
But hope to get a little closer.
if I dont find the problem this way, I think it must go to the Dyno
Old Today, 12:58 PM
The Analog Admin!
05stangkc's Avatar
Upgraded Your Title From V6 Member! I Think it has a Bit More Flare! Hope You Like It! If Not Happy To Change it to Something Different!
Best Regards,
Lookin4knowledge
1994-2004 V-6
4/15/21 09:53 AM
Chubbs88
1994-2004 V-8
7/8/12 12:40 PM
Flagstang
5/10/12 06:15 PM
thatguy32886
1994-2004 V-6
7/3/10 09:44 PM
porkster
9/15/05 05:22 AM
Quick Reply: Clicking sound from rear
