Electric Power Steering - 2013 V6
Old 5/16/24 | 01:18 AM
deepakkumar's Avatar
Hi, i got Mustang 2013 V6 2Door Coupe. Due to logged water my steering is not working.
I want to confirm whether model from 2011 to 2014 EPS is suitable for my car
My EPS part no is DR33-3D070-AB (FoMoCo)
Is S197 Duralo EPS rack & Pinion CSW Part No: 247-0070 Suitable for the above
Can you please suggest
Old 5/16/24 | 09:11 AM
05stangkc's Avatar
The Analog Admin!
Put in Correct Wheel Size at Top of Header For Correct Part Number. I Put in 17" Wheels Since You Had a V6
Or See Will This Fit My Vehicle Tab.
https://www.buyautoparts.com/buynow/...8bcf320a1cb829
The FORD Number You Provided is a Ford Id# Which is Close To Part Number But Not Service # Part Number. If You Would Like Service Number For Cross Reference Provide Vehicle Vin Number.
Old 5/16/24 | 11:57 PM
Old 5/17/24 | 05:39 AM
05stangkc's Avatar
The Analog Admin!
These are All Correct Service Part Numbers For Your Car.
DR3Z3504AE
DR3Z3504ARM
  • Part Description
    Gear Assy - Steering
  • Base No.
    3504
  • Replaces
  • CR3Z-3504-AE, BR3Z-3504-KE, STE-48, STE-76
Glenn (5/17/24)
Old 5/17/24 | 05:43 AM
05stangkc's Avatar
The Analog Admin!
Interchange Part Numbers
18030119-101 18030119-102 18030119-103 18030119101 18030119102 18030119103 247-0071 2470071 FORD{DR3Z3504AE} STE67 DURALO{247-0071}
Glenn (5/17/24)
Old 5/18/24 | 09:10 AM
Siber Express's Avatar
The difference in the rack for different Mustangs is the steering stops for 19 inch and up wheels
m05fastbackGT (5/18/24)
Old 5/18/24 | 10:53 AM
05stangkc's Avatar
The Analog Admin!
Correct. It Limits Turning Radius So Wheels Don't Rub at Full Lock With The Larger Wheels!
Old 5/18/24 | 12:23 PM
m05fastbackGT's Avatar
Does that also apply to the older 2005-10 models? IIRC, models which were factory equipped with 16'" wheels had different steering stops over models which came with 17" wheels and also with the optional 18" wheels... If also I'm not mistaken, I believe the steering stops for the 2007-10 Shelby GT500 models also had different steering stops when compared with the base V6 and base GT models as well...
Old 5/18/24 | 12:24 PM
05stangkc's Avatar
The Analog Admin!
Yep!
https://www.fordpartsgiant.com/parts...z-3932-ca.html
Ford 6R3Z-3932-CA Restrictor
2006-2010 Ford Mustang 6R3Z3932CA
Actually on the 2011-2014 Cars The Rack Rod Ends are Different Part Numbers For Wheel Size! They Come With The Restrictors When You Get FORD Ends. See The Blue Piece in First 3280 Listed and Black on The Last. So For Example If A Guy Had a Tire Rub Issue on Turning With a 17" Wheel Car That Had Wider Wheels Installed He Could Add The Rods and or Restrictors For Rub Issues!
https://www.fordpartsgiant.com/parts....html?pnc=3504
Rack
https://www.fordpartsgiant.com/parts....html?pnc=3280
Rod Ends
Rod - Tie
BR3Z-3280-C
Kit - Tie Rod
inner , Kit , RH/LH
    Passenger Side/Driver Side
  • Fit Note:
    , With Staggered Wheel
    Sizes, With 19" Wheels
  • Require Quantity:
MSRP: $63.27
$39.67
  • Add To Cart
BR3Z-3280-A
Kit - Tie Rod
inner , Kit , RH/LH
  • Fit Note:
    With 17" Wheels
  • Require Quantity:
MSRP: $63.27
$39.67
BR3Z-3280-B
Kit - Tie Rod
inner , Kit , RH/LH
  • Fit Note:
    With 18" Wheels
MSRP: $63.27
$39.67
BR3Z-C
BR3Z-A
BR3Z-B
Old 5/18/24 | 12:48 PM
That's what I thought, but wasn't 100% certain... Therefore, being as my 2006 GT premium originally had standard 17" wheels, would this mean that my car has different steering stops over the optional 18" wheel package? If so, would I need to update to the steering stops which were factory included with the optional 18" wheel package... My reason for concern is I have since upgraded from the OEM/standard 17" wheels to OEM 2007-09 Shelby GT500 wheels which are 18x9.5" in diameter...
Old 5/18/24 | 12:57 PM
05stangkc's Avatar
The Analog Admin!
As Long As They Never Rub on Full Lock You Are Fine! If They Do Rub Then a Restrictor May Do The Job! Tire Size Would be a Factor Too if Yours Are Wider or Narrower Than The Stock Gt-500 Tires!
Old 5/18/24 | 01:03 PM
Current tire size is 275/40/18" on all 4 corners vs stock GT500 255/45/18" front and 285/40/18" rear...
Josh Francis
Past Rumor Archive
4/13/18 12:16 PM
Linkspure
9/12/15 06:33 PM
GtStang4
6/5/14 09:44 AM
djdopemunky
1994-2004 V-6
10/9/07 05:42 PM
Quick Reply: Electric Power Steering - 2013 V6
