05-09 My Color, IUP & Gt-500 Cluster, Gauge Face Topics 2005-2009 My Color, IUP & Gt-500 Cluster, Gauge Face Topics
READ FIRST!!!! 2005-2009 S-197 Ford Mustang MY COLOR CLUSTER & GAUGE FACE ARCHIVE!
Old Sep 29, 2023 | 04:41 PM
05stangkc's Avatar
I Can't Believe How Many My Color & Dash Related Threads I Found on The 05-09'S So Far About 45!
Some I Have Already Deleted as They Were Not of Value. I Made a New Section Due To The Amount of Threads! and Will Go Through These And Do Some Weeding!
But if Anybody Comes Looking For the info Well Here You Go!
After I Finish Going Through These Threads I Will Do a Step by Step Easiest Route to Do the My Color Upgrade. It Will be Written in Such a Way If You Have To Go to The Dealer I Will Advise How To Get it Done as Cheap as Possible in Whatever Scenario Arises! So Stand By!
My Original Thread Still Works To A Point But Needs To Be Updated As Few Will Purchase a New Cluster These Days at The Dealership!
OK!
Mgb,
KC
This Will Eventually Become The Master My Color Forum Work in Progress! 09/29/2023
READ FIRST
Last edited by m05fastbackGT; Jan 24, 2024 at 04:25 PM. Reason: Typo Correction In Title
Old Sep 29, 2023 | 07:13 PM
05stangkc's Avatar
The Message Center Switch. Fits 2005-2009
Note They Have Gone {Obsolete} so a Used Switch at Wrecking Yard or NOS if Can Find One on Ebay!
NOTE I USUALLY HAVE 1 or 2 Of These on Ebay I Just Feel Since I Invented The My Color Conversion & Still Sell Some NOS & Used Ford Parts at Times I Would Get These When I Come Across Them & Have Them For TMS Members & Viewers.
Ebay Sales
6r3z-18578-aa
https://www.ebay.com/str/clevengerfo...mis&media=COPY
clevparts@aol.com 09/27/2024
If You Do Not Have My Color You Need To Pull Dummy Plug Out & Wiring Should be Clipped to It!
Most Cars Will Have it But Not All!
https://www.fordpartsgiant.com/parts...tra2=&filter=()
For Those Without Wiring and Bound & Determined to Add Anyway. I Believe This is All the Related Wiring Info You will Need! I think You Will End Up Needing 3 Plugs To Get the Wiring With Pins. 1 at Message Center ,1 at Cluster & 1 Of The Sjb Plugs All Scavenged Out of a Mesage Center Car Unless You Want to Pull Entire Harness Out of a Wrecked Car.
THE FIRST THING YOU MUST DO IS CHECK FOR THE WIRING! LOOK AT THE CLIPS ON THE SWITCH SAME AS ON DUMMY PLUG! THOSE NEED TO BE PUSHED DOWN TO RELEASE DUMMY PLUG! THE WIFE'S METAL NAIL FILE SHOULD WORK GREAT! INSERT AND LIFT UP ON TOP OR DOWN ON BOTTOM. WIGGLE OUT GENTLY SO AS NOT TO BOOGER UP RADIO PLATE! OTHERWISE RADIO PLATE WILL NEED TO BE REMOVED! NO WIRING NO DICE! SO CHECK THIS BEFORE DOING ANYTHING ELSE! WIRING SHOULD BE SNAPPED INTO REAR OF DUMMY PLUG!
This Can Be Installed at any Time! It Will Merely Light Up and Effect Nothing! I Had Mine In Before Cluster Install!
Ford 6R3Z-18578-AA Switch Assembly
NO PLUG LINK
https://themustangsource.com/forums/...3/#post7080118
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 29, 2023 | 07:52 PM
05stangkc's Avatar
These Are Some Shop Manual PDF'S Relating to Cluster Operation and Some Surrounding Area's. I List them as FYI'S as You Will Not Need All This Info For the Cluster Swap but it is Good Info if You are Wanting to Know How Everything Functions. The Way The Shop Manual is Set up You can Get Overlap in the Files and They are Not As User Friendly When Not Used Online!
2005-2009 DTC CODES
https://themustangsource.com/forums/...e-info-550470/
Enjoy,
Mgb,
Kc
Old Sep 29, 2023 | 08:21 PM
05stangkc's Avatar
BASE V6 4 Gauge 5500 Redline 120 Mph
GT V8 4 Gauge 6000 Rpm Redline 140 Mph
V6 My Color 5500 Redline 120 Mph
Gt My Color 6000 Rpm Redline 140 Mph
Bullitt My Color, Different {Number Font than Gt} Old School Look!
NOTICE BULLITT HAS 500 Rpm Higher Redline! INTERESTING! 6500 Redline 140 Mph
Gt-500 Instument Cluster 160MPH 6000 Rpm Redline
Saleen My Color Gauges 200 Mph
Old Sep 29, 2023 | 08:29 PM
05stangkc's Avatar
Cluster Repair For Stepper Motors!
Old Sep 29, 2023 | 08:34 PM
05stangkc's Avatar
Aftermarket Gauge Faces
https://www.blackcatcustom.com/ford_mustang.htm
THESE CAN ALSO BE USED TO GO FROM KPH TO MPH OR MPH TO KPH!
Supposed to Be Black Cat Customs as Well!
Canadian Version in Kilometers
RANDOM OVERLAY PIC THANK HOSS 007 Also Jim 010 For Canadian Pic
Old Sep 29, 2023 | 09:48 PM
05stangkc's Avatar
Older List of Cluster ID Numbers! All Are 2007 Model Numbers! Don't Mix Up MPH with KPH!
Id Numbers are Numbering on Actual Assembly, Part Numbers are What is in Parts Catalog EXAMPLE.
https://www.fordpartsgiant.com/parts...-10849-fa.html
(cluster), KPH, 4.0L (SOHC), 6 gauge cluster, ID 7R33-10849-FA Would Be Part Number 7R3Z-10849-FA Close But Not Identical.
(cluster), KPH, 4.0L (SOHC), 4 gauge cluster, ID 7R33-10849-BA
(cluster), KPH, 4.6L (3V), 6 gauge cluster, ID 7R33-10849-HA
(cluster), KPH, 4.6L (3V), 6 gauge cluster, ID 7R33-10849-HB and HC
(cluster), KPH, 4.6L (3V), 4 gauge cluster, ID 7R33-10849-DA
(cluster), KPH, 4.6L (3V), 4 gauge cluster, ID 7R33-10849-DB and DC
(cluster), MPH, 4.0L (SOHC), 6 gauge cluster, ID 7R33-10849-EA
(cluster), MPH, 4.0L (SOHC), 4 gauge cluster, ID 7R33-10849-AA
(cluster), MPH, 4.6L (3V), 6 gauge cluster, ID 7R33-10849-GA
(cluster), MPH, 4.6L (3V), 6 gauge cluster, ID 7R33-10849-GB and GC
(cluster), MPH, 4.6L (3V), 4 gauge cluster, ID 7R33-10849-CA
(cluster), MPH, 4.6L (3V), 4 gauge cluster, ID 7R33-10849-CB and CC
(cluster), KPH, 5.4L (Shelby GT 500), 7R3V-10849-BA thru BC
(cluster), KPH, 5.4L (Shelby GT 500), 7R3V-10849-BD
(cluster), MPH, 5.4L (Shelby GT 500), ID 7R3V-10849-AA thru AC
(cluster), MPH, 5.4L (Shelby GT 500), ID 7R3V-10849-AD
(cluster), KPH, 4.0L (SOHC), 6 gauge cluster, ID 7R33-10849-FB and FC
(cluster), KPH, 4.0L (SOHC), 4 gauge cluster, ID 7R33-10849-BB and BC
(cluster), MPH, 4.0L (SOHC), 6 gauge cluster, ID 7R33-10849-EB and EC
(cluster), MPH, 4.0L (SOHC), 4 gauge cluster, ID 7R33-10849-AB and AC
__________________
Old Oct 1, 2023 | 10:13 PM
05stangkc's Avatar
hold
Old Oct 1, 2023 | 10:20 PM
05stangkc's Avatar
FOR REFERENCE USE!
https://www.fordpartsgiant.com/parts...html?pnc=10849
All 2005 Cluster Part Numbers
All 2006 Cluster Part Numbers
All 2007 Cluster Part Numbers, NOTE TPMS EQUIPPED YEAR
All 2008 Cluster Part Numbers Note Later Year Listings Using Prior Model Part Numbers, NOTE TPMS
All 2009 Cluster Part Numbers Note Later Year Listings Using Prior Model Part Numbers, NOTE TPMS
Old Dec 15, 2023 | 04:44 PM
05stangkc's Avatar
Link To VGM Studio Post on Custom Gauge Face!
https://themustangsource.com/forums/...2/#post7060714
Kc
Old Jan 21, 2024 | 10:51 AM
05stangkc's Avatar
Foose Gauge Overlays!
https://www.ebay.com/itm/16264301313...wAAOSwCotZnZX2
USMC xI2aMpAnTx
27
Sep 30, 2023 01:30 PM
351pony
Apr 6, 2010 02:55 PM
snster
Sep 25, 2009 03:43 PM
