HELP, 2017 Mustang Keyless Entry and dome light issue
Hi Everyone,
I just got a 2017 Mustang, and I am loving it. The only thing I had a question about has to do with the keyless entry as well as the dome lights in the vehicle. When I open the door to get in the car, the dome lights do not come on automatically for whatever reason. Going into the settings on the information display does not give me any options related to this. Could this be a blown fuse somewhere? My other question has to do with Keyless Entry. When I go to lock the doors on the car, the doors will lock, but none of the lights whatsoever on the car flash, so the only confirmation I have is to listen to the doors lock. Pressing the button twice does not chirp the horn like it should either. Has anyone here had either of these issues, and if so, how did you fix them?
Welcome!
I Found This Post and Also Do You Have an Owners Manual if Not Here is a Link To a PDF Version!
Also Moved You To Service & Repair Section!
https://themustangsource.com/forums/...lights-547388/
https://themustangsource.com/forums/...p-ford-549326/
KC
Just Remembered I Posted a Ton of Pdf's on Similar issue Here!
https://themustangsource.com/forums/...switch-551170/
KC
MustangOldYellow
Repair & Service Help
Jun 8, 2024 10:22 PM
Wajee50
Jun 6, 2024 09:18 PM
