Repair & Service Help All Repair related problems, issues, TSBs, and anything else revolving around the Repair of your Mustang
HELP! 2015 mustang wont turn on or start!
Old Apr 18, 2021 | 11:06 AM
Travis Taylor's Avatar
So I upgraded the 4 inch radio to 8 inch touchscreen, bezel, with wiring harness to go from Sync 1 to Sync 2. The radio will come on when I press power on it and everything seems to work.
But my push to start wont light up or turn accessory on even. So my car is all of a sudden at a stand still. I tried the old bezel even with the harness and still nothing on the button. Any idea what to do or what i may need to fix this issue?
Old Apr 18, 2021 | 11:37 AM
houtex's Avatar
My first thought is you've disconnected something and then didn't connect it back correctly. Done that myself, it happens. I'm sure you've double checked it. Also, pins get bent, or the sockets get pushed out of the connectors. So maybe check that.
Second thought is similar, but something went wrong when (dis)connecting and you popped a fuse or some fuses.
Overall, though, you probably need a shop manual to figure this out now. And/or a multimeter. And/or a test light. And/or a power probe. And/or an array of fuses when you 'oops' the wires. The diagnostics in the shop manual will lead you right to the problem(s) that are causing this.
I don't suppose the car is saying 'key not detected'...? But if it is, this video will help maybe:
Hope that helps, and welcome to the forums!
Payzak
Mar 24, 2023 02:25 PM
Aquillies
32
Sep 14, 2019 12:18 PM
MartinM
Jul 21, 2016 12:49 AM
Mr. V
Jul 30, 2014 03:54 PM
clucas
'10-14 Interior and Audio
18
Mar 3, 2014 05:47 PM
