2017 still leaking
2017 still leaking
Hi you guys!
some of you may remember i posted several months ago about my 2017 leaking water on the inside just above gas pedal, with air on AND windows down.
So ive been driving with no air until this week. This week it was windows UP AND air ON AND.......there was a leak....STILL.
I spoke with the Sames Ford Customer Service Manager, who said they wld call me...its been two days now.....IM SO SAD ABOUT THIS....
I'm wondering if that's coming through one of the grommets that go through the firewall. If you don't get that fixed, over time the interior of your car will start to have a mold smelling stench. I've had many cars in the past that have that smell and it utterly sucks.
I had a similar problem with my 2005 GT. I noticed water literally pouring in on the passenger side and could not figure out where it was coming from. One day I got curious and removed to cowl panel from under the windshield wipers and found the water was coming in from my cabin air filter. The was a rubber grommet that was stuffed full of pine needles, dead leaves and black slime the the grommet couldn't drain water. There was at least 2" of water in the compartment, enough to reach the bottom of the filter and soak through the filter. That's what was causing my leak. I took out both grommets (there was one on the drivers side which had the same amount of water but no way to get into the car so I didn't even know it was full) and I never had an issue again.
The problem I see is that if one mechanic is assigned and he tries to diagnose it by himself, the leak could be overlooked. It's easier if 2 people look for the leak. One goes under the dash while the other squirts the water. Most places will not assign 2 mechanics to do a job.
Just 1
Low Freon?
So Sames Ford, in Bastrop Tx has now had my 2017 Mustang 2 weeks coming on Monday.
Today they messaged me to say, it had low freon, which caused excessive condensation, and WAS a known issue. If this is a known issue, why have I been dealing with this since last August? They said due to the extra condensation, it was NOT able to drain fast enough and would drip down on my foot, inside the car.
My question was: shouldnt the drip pan drain as fast as it fills? UNLESS there was a drip pan clog or blockage? (No answer yet)
Im just in awe!
Im just in awe!
You do know you can take your Mustang to any Ford dealer you want to? I ordered and received my Mustang (2011) from a Ford dealer 15 miles from me. All of my recalls, warranty work etc. has been done at a Ford dealer 5 miles from me, with no problems at all
Check around and read reviews about the other Ford dealerships near you.
Evil_Capri
Which is Better
Jun 18, 2017 11:40 AM
BlackStang14
Jun 5, 2015 09:38 AM
2005 Black GT
May 10, 2005 08:30 PM
