Help! Passenge Side front wheel leaking grease!
Old May 9, 2005 | 05:26 PM
2005 Black GT's Avatar
I discovered green grease all over the inside front wheel well of my front right passenger side wheel. What could this possible be? It appears to have leaked, and then the tire threw it all over the wheelwell.
Old May 9, 2005 | 06:22 PM
Sonic05's Avatar
The only thing there to leak grease is the wheel bearing, and that is sealed . . . or should be anyway.
As always, take it to the dealer.
Old May 9, 2005 | 06:25 PM
groupset's Avatar
Originally posted by Sonic05+May 9, 2005, 6:25 PM--><div class='quotetop'>QUOTE(Sonic05 @ May 9, 2005, 6:25 PM)</div><div class='quotemain'><!--QuoteBegin-2005 Black GT@May 9, 2005, 6:29 PM
[/b][/quote]
Probably faulty bearing. Easily remedied, but get it to the dealership soon.
Old May 9, 2005 | 06:44 PM
red454's Avatar
Sounds like a damaged wheel bearing seal. Easy fix.
When you go to the dealer, have the hub and bearings inspected.
Make sure they clean the grease off of the wheel, tire, inner wheel well and anything else that got "greased".
If it leaked from the inside of the rotor, have the brakes checked / cleaned too.
Let us know how it goes for you.
Old May 9, 2005 | 07:00 PM
Mr. 'Stangster's Avatar
That is Fords optional, on demand, free undercoating. The left front should be available as an option in your near future !
Old May 9, 2005 | 09:13 PM
Mongoose's Avatar
Are you sure you did not run over the grease?
Old May 10, 2005 | 02:57 PM
Went to the dealer to have it checked out, no problems. I must have run over it somehow, but I don't remember running over anything or hearing noises. Just seemed fishy to me so I took it to the dealer just in case. Saw the Ford GT they just got in, white with blue stripes. Gorgeous.
Old May 10, 2005 | 05:52 PM
Greywolf's Avatar
Probably ran over a small tube of grease
Old May 10, 2005 | 08:30 PM
wild stray's Avatar
Any lube men missing?
sarnold58
Jun 9, 2019 02:22 PM
RRRoamer
Jan 19, 2017 05:27 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
TrueBlue302
Jul 23, 2015 06:13 AM
