lucas oil stabilizer? UPDATE! Oil Additives in General Discussion!
i bought a bottle of this stuff and before i actually use it i wanted to know what you guys think of it. i tried searching but found the few posts on this pretty vague where i wasnt convinced either way.
any suggestions would be very helpful
thanks
thanks
I would stay away from any oil additives. Not necessary with modern oil technology. If you are using any API SM rated oil (dino or synthetic), no need for additives. Regular oil changes and any decent quality oil = your engine will outlive the rest of the car.
i guess il go get my 10 bucks back then
its that **** displays fault!! ..stupid gears with the oil sticking better just makes you think..wow thats gotta be great stuff.
![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
im a sucker for direct advertising. heh
I'm still using up all the free oil I got from O'Reilly's after rebate. I see they are running another free after rebate offer now. QAdvanced and Valvoline SynPower full synthetics are both free after rebate. 5W30 only, but they will work just fine, I promise. www.oreillyauto.com
5-20 is just fine (obviously, Ford recommends it). I'm just saying that there is nothing to be afraid of with 5-30. It really isn't that much thicker at operating temps, and will only reduce your mpg by maybe .2-.3mpg.
There have been many engines, the 4.6 included, that were back-spec'd for 5-20 after the manufacturer recommended 5-30 for many years.
I used to sell alot of lucas additives to loggers and truck drivers when I worked at NAPA alot of people swore by it. But in my stang I just use good clean syn oil and quality filters.
Mike
Mike
Check out Bob the Oil Guy's web site, he has a feature on Lucas oil stabilizer, based on his tests and info, I'm not really a fan of it, the upper engine lubricant on the otherhand, I like very well.
The cheapest 5W-20 you can find will be a semi-synthetic. The specification pretty much requires that it be a semi-synthetic, just like Mercon-V.
With respect to API SM and ILSAC GF-4 requirements, even the dino oils are performing more and more like Group III synthetics.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
UPDATE!!!!!!!!!!!!!!!!!
Shelby Used To Push This!
Mgb,
KC
Mgb,
KC
I Love the BG Products! Used & Sold it For Years At Various Ford Dealerships I Worked At! The MOA is a Great Additive I Used For My Older High Milage Pushrod Motors and I Also Like in My Supercharged Harley F-150. These Trucks Have Notorious Blowby & Get Timing Chain Start Up Noise & Moa Seems to Help!
Oh And The 44K is a Great Fuel Additive!
https://www.bgprod.com/
NC14GT (9/25/23)
