GT350
Evolution Performance, Inc. - 2016 Shelby GT350 Basline Dyno Numbers
Old Nov 12, 2015 | 01:05 PM
Rob@Evolution's Avatar
Former Vendor
Our 2016 Shelby GT350 with only 110 miles on it hit the rollers.
On 93 Octane it made 447 RWHP and 382 RWTQ 100% Stock on our 1100-SE Mustang Dyno.
The car will be Tuned Exclusively with the Lund Racing nGauge for 93 Octane and also for e85 so stay tuned.
Attached Thumbnails Evolution Performance, Inc. - 2016 Shelby GT350 Basline Dyno Numbers-2016-gt350.jpg
Old Nov 12, 2015 | 01:34 PM
tom281's Avatar
Decent numbers. Like the color combo.
Old Nov 12, 2015 | 07:23 PM
lime05's Avatar
Subscribed. Can't wait to see some videos
Old Nov 13, 2015 | 10:26 AM
1 Alibi 2's Avatar
Nice baseline, what are the mod plans ??
Old Nov 13, 2015 | 01:01 PM
HizliBullet's Avatar
if that engine is similar to the coyote 5.0, where did they make it the extra .2 from? just wider valves?
Old Nov 13, 2015 | 01:13 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Valves have nothing to do with displacement, the size of the bore X stroke X number of cylinders = displacement.
Old Nov 13, 2015 | 01:32 PM
Former Vendor
Now that the baseline is done we are hard at work doing the R&D for the build. I will update as the build progresses.
Old Nov 13, 2015 | 05:10 PM
SplitSecond's Avatar
Definitely in for updates!
Old Nov 13, 2015 | 10:37 PM
That explains the 12:1 ratio compared to 11:1 on coyote
Old Nov 13, 2015 | 10:54 PM
Like Father...
I ♥ Sausage
Well, not really. Compression ratio is determined mostly by the size of the dome (or lack thereof) on the piston top and the size of the combustion chamber of the head.
Old Nov 14, 2015 | 07:25 AM
1 Alibi 2's Avatar
How about a hint, blower or turbo(s) ?
Old Nov 14, 2015 | 08:06 AM
GT_Dave's Avatar
The configuration is similar to the coyote, not the construction. The voodoo engine does not have cast cylinder liners, it has ceramic sprayed liners which allows a larger bore and the valve position to move for larger valves. This spray liner technology Ford brought inside their engine plant for this engine. Previous Shelby versions had the spray liner blocks done outside their plant by other sources.
The Coyote engine is 92.2mm bore, 92.7mm stroke
The Voodoo engine is 94mm bore, 93mm stroke
Old Nov 16, 2015 | 07:58 AM
Former Vendor
Our 2016 Shelby GT350 ran a 11.96 @ 116mph with 325/30R19 Mickey Thompson Performance Tires & Wheels ET Street S/S Radials and BMR Suspension Inc.. The car ran this number with the stock tune and on 93 Octane and is the first GT350 in the 11's. ‪#‎Shelby‬ ‪#‎GT350‬ ‪#‎Ford‬ #‎evolutionperformance
Old Nov 16, 2015 | 09:15 AM
Chad@Amp'D's Avatar
Former Vendor
Nice run!
Old Nov 16, 2015 | 09:23 AM
Former Vendor
Originally Posted by Chad@Amp'D
Nice run!
Thanks ... Would have had been better but the track prep wasn't at its best.
Old Nov 16, 2015 | 10:10 AM
Jazzman442's Avatar
How does this compare to the 2016 Mustang GT and the 2014 GT? Just curious since the 2014 is Quicker than the 2016?
Old Nov 23, 2015 | 01:47 PM
Former Vendor
New Best in our 2016 Shelby GT350 - 11.76@118MPH! The car weighed 4,025lbs with Driver.
Attached Thumbnails Evolution Performance, Inc. - 2016 Shelby GT350 Basline Dyno Numbers-gt350-time-slip-2.jpg   Evolution Performance, Inc. - 2016 Shelby GT350 Basline Dyno Numbers-gt350-scale.jpg
Old Nov 23, 2015 | 04:12 PM
That's not even the 'R' version. With less weight it should be even quicker. :-)
Old Nov 23, 2015 | 06:15 PM
orng302's Avatar
I think you need a lighter driver?
Old Nov 24, 2015 | 10:08 AM
Former Vendor
w\o driver it would be around 3850.
