Sponsored by:
Sponsored by:
Tire Recommendations?
Old Oct 12, 2015 | 05:03 AM
colt breaker's Avatar
Anyone already change their tires? If so, do you like them more/less than the OEMs? I've got the 19x8.5" rims, 255/40/19 P Zeros. They seem a little "squirrelly" in the turns.
Old Oct 14, 2015 | 08:09 AM
v8ter's Avatar
My Pirellis suck, I did 3 10sec burnouts and there fried!! Gona install Mickey Thompson street 285 35 19 on stock wheels , Ill tell you my outcome
Old Oct 14, 2015 | 08:51 AM
mhazelwd's Avatar
I think the stock wheels are 8.5" wide. I would not run anything bigger that a 255 on them
Old Oct 14, 2015 | 02:02 PM
Jazzman442's Avatar
That's what happens on a softer tire. if you want to burn out all day long get harder tires.
Old Oct 14, 2015 | 03:16 PM
Von Bek's Avatar
I don't need any yet, but I priced some out at work and Michelin Pilot Sport A/S 3s are ~$250 for fronts and ~$300 for rears. With a mileage warranty, so you take the hit on the original purchase but you get the prorating for the next set. I used them on my 07 GT and they were great.
Old Oct 15, 2015 | 06:50 AM
Yeah, they are 8.5". Tire Rack does show 285s as an alternative for the back, though. I like having the same size all around so I can rotate them.
Old Oct 15, 2015 | 10:17 AM
oneeyedgiant's Avatar
What kind of tires come from the factory on the GT Premium with Performance Pack? I know they are 275r/40 R19. But what is the manufacturer? By the time my car gets there its going to be winter and I am going to have to get all weather tires.
Is it important to get all 4 tires swapped out for all-weather? Or would replacing just the rears be sufficient?
Old Oct 15, 2015 | 10:25 AM
Joeywhat's Avatar
1) they are pirelli summer only tires.
2) under no circumstances (outside of certain racing situations) should you ever mix tire makes on your vehicle. This is even more true when talking about summer and winter compounds. You'd be better off just keeping the summer tires, at least it would be somewhat predictable.
If you want winter tires get all four.
Old Oct 21, 2015 | 07:51 PM
bob's Avatar
bob
255/40R19 on 19x9" front and 275/40R19 on 19x9.5" rears and they are summer tires. The rim offset is such that the 19x9.5 will not work on the front without driving the rim into the strut when its tightened up.
One of my neighbors found out the hard way when the techs at his stealership grabbed a rear PP wheel and put it on the front of his PP equipped GT and ended up replacing a wheel and strut on his car.
Old Nov 9, 2015 | 08:02 PM
rredd14's Avatar
I'm happy with the Mickey Thompson Street Comp tires. Nite and day different from the stock tires.
Old Nov 10, 2015 | 04:33 PM
Remenant's Avatar
I had the same concern about my performance pack car when it got pushed back. I actually ordered a set of Michelin Pilot Sport A/S3. They were 1300 for the set. I actually drove off the lot with them installed and they have been very good so far. We've gotten a lot of rain the past week and they held up very nicely. In the coming weeks we will be getting sub 45 degrees and I'll be able to see how they hold up with cold rain on the road. The Pirelli tires I simply stored until summer, however they should not be used anywhere below 45 degrees.
Old Nov 11, 2015 | 09:24 AM
101Charley's Avatar
I just put on new wheels and tires. ForgeStar CF5V 19x10 Front and 19x11 Rear in Matte Gunmetal. The tires are Michelin Pilot Super Sport 275/40/19 Front and 305/35/19 Rear. They fit perfectly. The car is a 2015 Mustang GT Premium (non-PP). The tires are much better than the Pirelli's. The difference is huge.
Old Nov 13, 2015 | 01:09 PM
Kotenukimen's Avatar
I have replaced my worn out stock Pirelli 255/40/19 by some Falken Azenis, and they are just awesome tires. They are predictable and they last longer than the PZeros. The only downside is the noise, but you get use to it after a few miles if noises are not your top priority. I did a little drift session and I was able to predict exactly the grip during oversteer. I will definately buy a new set next spring and I recommend them to any spirited driver.
Fred_Garvin
Sep 17, 2015 04:10 PM
