Sponsored by:
Sponsored by:
REAR DIFFERENTIAL AND AXLE CHANGE
Old Nov 3, 2018 | 12:05 PM
2018GT's Avatar
Installed a Ford performance loaded differential with 3.55 gears and a cast iron case to replace the aluminum cased differential and stock 3.15 gears. Also replaced the stock rear drive axles with the GT350 axles from Ford performance. Then using a hand held tuner recalibrated the speedometer for the new 3.55 gears. 2018 Mustang GT 10R80.
Old Nov 4, 2018 | 07:47 PM
Rpinaiii's Avatar
Dayum pretty cool. So for some one like me who has slight knowledge about the rear gear ratio, is the 3.55 better?
Old Nov 5, 2018 | 09:38 AM
2018GT's Avatar
The 3.55 gears will give my car better acceleration. Plus it is a change I wanted to do.
Old Oct 24, 2019 | 03:53 PM
Rpinaiii's Avatar
@2018GT did you change the gears yourself? Or a shop do it? If you don't mind, about how much was cost? I am considering swapping to 3.73 but not sure yet..thanks
Old Oct 24, 2019 | 07:30 PM
TheReaper's Avatar
Beware of the rev limiter because it will come quick.
muscledom
23
Feb 8, 2012 11:24 AM
Flojoe
Feb 11, 2011 04:15 AM
muskrat2000
1994-2004 V-8
Jul 25, 2007 05:32 PM
Final5pt0
Mar 10, 2005 06:40 PM
black gt 2005
Feb 16, 2005 01:56 PM
