H-pipe in stock exhaust
#42
Originally Posted by area5179
Yeah I have a massive amount of stuff on order from CJ Pony Parts for my 2019 GT and I don't even have the car yet.
![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
![Cheers](https://themustangsource.com/forums/images/smilies/cheers.gif)
#43
I keep coming back to this thread and checking out the AM Vid as well as doing some research...
We have a custom exhaust shop here and I gave them a call - they can do the bolt on h pipe res delete - but he recommends doing a custom job that is welded in as bolt ons can leak and move... has anybody done this? He can do it in either an H or X config - I'd do the H config, he's quoting $275 total for the job... probably the same price as buying the bolt on and having them do the install.... SERIOUSLY considering this option....
#45
#47
I don't know about the stock active exhaust. But I will say, with my non active stock exhaust there is more popping with the res delete h pipe than before. I didn't hearr any popping before.
#48
I have some decal burble and popping on my ‘14 GT with GT500 ABs and I’ve heard that deleting the resonator will increase that which I really like. I’m seriously considering a ‘19 now though so I’m not gonna mod the ‘14. I might have to go test drive a ‘19 with active exhaust though.
#49
#50
Yes - there is a small amount of snap/crackle/pop - but very very small... my 13 had the boss quad exhaust with gt500 ab's - depending how how I layered the clutch, I could pop pop pop all the way on decel... I just assumed the 10R80 won't pop as much because, it's an auto... *shrug* - once I get the H pipe installed I'm curious how much more pop I will get - I only run exhaust in TRACK mode...
#51
Today I Installed the MRT H-pipe resonator delete on my 2018 GT with the 10R80 auto trans. The resonator weighs 17 pounds and the pipe weighed in at 10.5 pounds. Not much of a weight savings but that is not the point of a h pipe or x pipe. Did the install by myself. Not terribly difficult just cumbersome. A much louder and slightly deeper tone to the exhaust now. I am very pleased with this rather simple modification.
#52
Hi guys I'm new on this site, not new to fiddling with my cars.
I approached an exhaust company to do the H pipe and they want to leave the resonater box and replace the rear end boxes?
i like the idea of just removing the resonater and running two pipes back down to the end boxes and fitting a H pipe? Two questions will it be stupid loud? And do I need to make all the fancy bends in it?
My car car is a 2017 GT 50
#53
captain greg (9/11/18)
#54
cant I make it using stainless pipe same OD and just run them straight without the fancy bends? I will put the H connection in?
or do you guys say I must purchase an after market H pipe ?
#57
ok so I had this made today and fitted it has improved the sound a bit, in comparison to my Aston V8 it's still very " dare I say a non event"
we addd a bracket at the rear to add strength near where it joins to the pipes leading to the back boxes
all in cost was around 50 USD we used stainless pipe,
#59
The 15-17 mufflers are very different from the 2018+. I'd still do an axleback kit. The stock mufflers are way too quiet. If you don't want it too loud you could do the Borla Touring or for a little louder go with the Corsa Sports.
#60
sudenly i think the thing is smoking am I being confused?
