Sponsored by:
Sponsored by:
GT 5.0 Heads Up on Anti Hop kit and reversed cats
Old Mar 24, 2015 | 01:03 PM
retiredf5's Avatar
Was in for service today and the tech told me that there is a new anti hop kit for the 2015. Also, the dealers have gotten a Service Bulletin to check all 5.0 as there are a small number of them that had their Cats installed in the reversed direction.
Old Mar 24, 2015 | 01:08 PM
retiredf5's Avatar
I should have added to the above on the cats . . . I Was told that a visual check can ID the incorrect fit so I suspect part numbers etc are on the bottom of the cats if installed correctly.
Old Mar 25, 2015 | 08:46 AM
mikeyt03's Avatar
That is correct, but they issued that in December of 2014 and dealers had to fix them prior to selling the car, so If you purchased your car in 2015 you should be good to go.
Did you happen to get the tsb number for the anti hop kit? I hope they replace the bushings with the frpp ones.
Old Mar 25, 2015 | 08:56 AM
LQQK's Avatar
+1-->
Old Mar 25, 2015 | 09:52 AM
mikeyt03's Avatar
Called my dealer and he found nothing on a wheel hop tsb.
Old Mar 25, 2015 | 10:03 AM
LQQK's Avatar
Maybe the tech was letting him know that one (anti hop kit ) is available in the after market.
TSB on the cats, separate subject-->
Old Mar 25, 2015 | 10:04 AM
SpectreH's Avatar
OP didn't state there was a TSB for wheel hop, just a kit. Of course if this is an actual problem, it should become a TSB. There is a TSB for the CAT issue.
Edit: LQQK beat me to the punch.
Old Mar 25, 2015 | 03:29 PM
tj@steeda's Avatar
And Steeda is actively addressing that problem with our line of S550 parts!!
You can check them out there:
http://www.steeda.com/2015-mustang-parts-home/
http://www.steeda.com/steeda-s550-mu...-all-555-4120/
http://www.steeda.com/steeda-s550-mu...-all-555-4121/
http://www.steeda.com/steeda-s550-mu...2015-555-4437/
& many more to come ...
Best Regards,
TJ
Old Mar 29, 2015 | 06:39 PM
mikeyt03's Avatar
Man...every time I turn while accelerating from a stop I get wheel hop.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
earl610
Sep 7, 2015 11:57 AM
