Gear indicator 10sp auto
If at any time, even when in normal mode you hit one of the paddle shifters, your car will be in manual mode and you will see the gear it is in. If you do not change gears manually, it will default back to auto mode and the gear indicator will go out. I do this when passing cars on the highway. I just hit the downshift paddle and boom, go for it instead of waiting for the transmission to downshift on it's own.
I will never understand the people that design Mustang software. With the shifter in sport manual mode it will show what gear the trans is in with a small amber number near to the odometer. That is how it should work no matter what gear the shift lever is in or what drive mode has been selected.
I will never understand the people that design Mustang software. With the shifter in sport manual mode it will show what gear the trans is in with a small amber number neat to the odometer. That is how it should work no matter what gear the shift lever is in or what drive mode has been selected.
