Check engine light came on
This morning I was driving and my tach flashed red .then I noticed my check engine light came on . Any ideas ? Car seems to run great .
I have seen some other posts with similar situation; apparently when you hit the rev limiter, it cuts ignition which causes a temporary misfire, and the computer sees that as a problem and triggers the Check Engine Light (CEL) .... I think it will go away by itself, if it does not go away, you might need to reboot the system by disconnecting the battery for a while
