Sponsored by:
Sponsored by:
Check engine light came on
Old Aug 9, 2022 | 07:57 PM
Garys2015gt's Avatar
This morning I was driving and my tach flashed red .then I noticed my check engine light came on . Any ideas ? Car seems to run great .
Old Aug 10, 2022 | 06:15 AM
did you hit redline when the tach light up?
Old Aug 10, 2022 | 08:37 AM
Yes it appears I hit redline
yes it appears I hit redline
Old Aug 10, 2022 | 08:42 AM
Bert's Avatar
I have seen some other posts with similar situation; apparently when you hit the rev limiter, it cuts ignition which causes a temporary misfire, and the computer sees that as a problem and triggers the Check Engine Light (CEL) .... I think it will go away by itself, if it does not go away, you might need to reboot the system by disconnecting the battery for a while
Old Sep 20, 2022 | 01:22 AM
MarvinN888's Avatar
If uncomfortable using the machine my experience is that many Auto Stores, Wallwork, Auto Zone etc will read the codes for free. The shop I use never charges to read a trouble code. That is my experience.
Black GT 5.0
Jun 26, 2017 03:29 AM
aflannery97
Nov 1, 2016 07:50 AM
2005GeeTee
Oct 2, 2013 10:02 PM
theedge67
Nov 5, 2006 02:46 PM
