Sponsored by:
Sponsored by:
2017 Mustang GT Camber Alignment after lowering car
Old Jan 29, 2017 | 08:07 AM
orlandoGT2017's Avatar
Guys
I had my car lowered by 1 inch with new springs, and after that I've noticed that the camber on the rear tires appear to be off a little. The bottom of the tire is positioned outward a little. I am not sure if that was the case before the springs were installed, however, I need to know if I should be concerned with that. Any thoughts?
Old Jan 29, 2017 | 11:18 AM
CoyotePremium13's Avatar
A 1 inch drop probably won't matter as much. It probably did adjust the camber slightly, but is still within spec. If it is a concern you can always get an alignment check. I also did a 1 inch drop on Eibach's and when I got my alignment they didn't adjust anything and was still within spec.
