Ecoboost
Can premium fuel cause a check engine light?
Old Sep 3, 2016 | 07:04 PM
stangchief's Avatar
2016 eco with 9800 mIles and I get a check engine light out of no where. I did put premium fuel in but had gone through almost 1/2 a tank before the light came on. Could it be the higher octane fuel? Can higher octane hurt the engine?
Old Sep 3, 2016 | 08:08 PM
5.M0NSTER's Avatar
No. Higher octane is not to blame. It can't hurt the engine. Opposite is true. If you have a 91 octane tune, but run 87 you can get premature ignition, or knock. But not the other way around.
Unless the fuel was somehow contaminated, it has nothing to do with your engine light. Have the dealer check out the DTCs stored in the engine ECU.
Old Sep 3, 2016 | 08:15 PM
SpectreH's Avatar
Gas door not sealing causing evap leak code?
Old Sep 3, 2016 | 08:19 PM
stangchief's Avatar
Already double checked the gas cap/door
Old Sep 4, 2016 | 08:10 AM
5.M0NSTER's Avatar
it could by any of the O2 sensors, crank potion sensor, fuel pressure sensor and so on. Your dealer or even autozone can read the codes and tell you.
Branden Cardenas
Aug 4, 2016 11:31 AM
evl5.0
Jul 26, 2016 12:30 PM
Dan19067
Jul 16, 2016 05:11 AM
jonser
Ecoboost
Jun 28, 2016 01:53 PM
mark0006
Jun 21, 2016 07:11 AM
