Widest front wheel 11-14 GT mustangs
Old Sep 13, 2014 | 07:39 PM
Dylanwhis's Avatar
I was wondering if a 10 inch wheel up front would fit? I plan on going forgestar F14's with a 285 35 ZR19 michelin pilot super sports. Will that fit without rubbing up front. Right now I am at stock ride height but eventually plan on lowering it 1 inch.
Old Sep 13, 2014 | 07:57 PM
BaknBlk's Avatar
I run a Forgestar CF5's in a 19X9.5 all the way around with 285/35/19's. I know there are guys running 10" wide rims up front, just need the right offset.
Old Sep 13, 2014 | 08:22 PM
Dylanwhis's Avatar
What would be the right offset?
Old Sep 13, 2014 | 08:25 PM
Dylanwhis's Avatar
Old Sep 14, 2014 | 05:57 AM
2006mach1's Avatar
Not sure about 19's, but I run Forgestar CF5's in 18 X 11 up front with 305's. You need to run some negative camber for the tire to clear though. Not sure about backspacing either as I had purchased these thru Vorshlag.
Old Sep 14, 2014 | 05:58 AM
bodon's Avatar
Call Weld wheel. They are very helpful with those questions.
Old Sep 14, 2014 | 11:51 AM
Dylanwhis's Avatar
Front wheel upgrade. Need help!
I plan on upgrading the wheels and tires on my 13' mustang gt with track pack and I was wondering if a 10 inch wide wheel would fit up front (19 inch tall)? I would put 285 35 19 michelin pilot super sport tires. It is lowered 1 inch with steeda springs. The wheels would be forgestar F14's. Would there be any rubbing? The offset it +42mm
Old Oct 25, 2014 | 07:42 PM
speedform's Avatar
My 18x10's are 43 offset up front (285 section tire). I believe Forgstar also sells a 19x10 w/43 offset. 285's should be fine with front strut type suspension but keep in mind tire choice as well. For example, a BFG Rival 285 runs WIDE (they look like 305 section tires!), so that should also play into your consideration. Running coilovers up front would give you a bit more wiggle-room.
Jul 20, 2015 06:26 AM
Jul 17, 2015 05:40 PM
