Suspension upgrade advice for 2012 gt
Old Jan 23, 2013 | 05:59 AM
OhMy5Oh's Avatar
Originally Posted by SlowRiderr
Can you recommend a particular spring, damper, and sway bar set that you find performs best for the dollar? Im interested in light track and auto-x time as well
Edit: how about the eibach kits or the frpp kits?
I've installed the FR track kit in my '11 GT. Did it myself. Easy install. Did not need spring clamps to convert over.
Since it's a complete kit, everything works together. Comes with the GT 500 top mount (much beefier than stock) adjustable front sway, etc. Lowered the car 1". It was already off center from the factory. Installed an adjustable panhard bar (easy). Camber bolts cheap and did the trick. Camber plates will give you more adjustment but for once-in-a-while track time, don't go crazy.
Ride is stiff. Corners almost flat. Turns in nice. Reduced nose dive on braking a lot. Little oversteer on exit. Lots of fun.
The only thing I would suggest with the FR package is get the adjustable shocks for the extra $200
Old Jan 23, 2013 | 09:05 AM
FAST FRED's Avatar
Which FR kit did you actually Buy /
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
JonathonK
Sep 29, 2015 09:27 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
