Suspension?
Suspension?
Hello everyone,
I have a 2011 GT 5.0. I'm having a problem with a single clunk/knock sound which seems to be coming from the rear end (both sides). Most noticeable when going up a driveway at an angle. No problems on flat surfaces. I'm the second owner. The first owner dropped the vehicle 1.5" all the way around. Installed Eibach Sportline springs and swaybar but kept the factory shocks and struts. I've had it to numerous shops up on lifts and the clunk cannot be duplicated while on the lift (frustrating). Opinions are all over the place - you need new shocks and struts, you don't need new shocks and struts, etc, etc, etc.
Hello everyone,
Guess it's possible, if the stock end links were on the sway they may be at an angle and not perpendicular like they are from the factory. I had a similar sound once I lowered my car. Only happened at low speeds over speed bumps, or over into a driveway. Ended up going away, I did pack the bushings with grease though so that may have helped resolve it.
I think I would get the dealer's suspension expert and take him for a ride with you. Usually once they hear it, while in the car, they can narrow down the cause.
I know nothing about suspensions or mechanics; but.... here's a simple one to rule out.
... since you're a new owner, is everything in your spare tire compartment secured?
Also if you get under the car, shouldn't need to jack it up, and hit parts of the rear suspension with your palm and see if you can track down the noise. That is how I traced the noise on my car to the endlinks. And you can drive with the back seats down to hear the noise more clearly.
Hello everyone,
I see you have a couple of mods, but I’d like to get this escalated for you. This way your dealer and the customer service manager can work together to find where this noise is coming from. Please make an appointment and PM me with your VIN, dealer, mileage, full name, and best daytime number. Please remember, this may or may not be a customer pay repair.
Deysha
Hi p0ny,
Deysha
Deysha
stock shocks work for the stock springs, once you take them out of their useable range they tend not to work so well. I had that problem with a lowered car and when I replaced the stock struts and shocks it solved the problem.
lets say the stock shocks have a working range of 2.5 inches and when you drop it with lowering springs you take away some of the usable 2.5 inches. you might end up with 1 inch of usable shock and then after that you have nothing.
