Suspension?
Old Sep 24, 2013 | 08:38 AM
p0ny's Avatar
Suspension?
Hello everyone,
I have a 2011 GT 5.0. I'm having a problem with a single clunk/knock sound which seems to be coming from the rear end (both sides). Most noticeable when going up a driveway at an angle. No problems on flat surfaces. I'm the second owner. The first owner dropped the vehicle 1.5" all the way around. Installed Eibach Sportline springs and swaybar but kept the factory shocks and struts. I've had it to numerous shops up on lifts and the clunk cannot be duplicated while on the lift (frustrating). Opinions are all over the place - you need new shocks and struts, you don't need new shocks and struts, etc, etc, etc.
Old Sep 24, 2013 | 09:16 AM
Brandon302's Avatar
May be the shocks, or the rear endlinks, do you know if the stock endlinks are on the car with the new sway?
Old Sep 24, 2013 | 09:20 AM
radioguy1's Avatar
Originally Posted by p0ny
Hello everyone,
Ford dealer should be able to diagnose that. They certainly see enough Mustangs with suspension issues???? Obvious first step is to look underneath for any thing loose like exhaust.
Old Sep 24, 2013 | 09:22 AM
Ltngdrvr's Avatar
Driveline slack maybe.
Old Sep 24, 2013 | 09:27 AM
Brandon302's Avatar
Could be the over axle pipes, could always hit them and see if they make a clunk inside the car.
Old Sep 24, 2013 | 12:17 PM
p0ny's Avatar
Not sure. When up in the air everything is tight and looks great.
Old Sep 24, 2013 | 12:23 PM
p0ny's Avatar
Ford thought the shocks were too long and should be shorter. I mentioned that the old owner installed Eibach Sportline Springs and did not replace the factory shocks and struts. The exhaust has a loose clamp which was tightened but still hearing the clunk sound.
Old Sep 24, 2013 | 12:47 PM
p0ny's Avatar
will the vehicle flex when going at an angle up a driveway?
Old Sep 24, 2013 | 01:25 PM
Brandon302's Avatar
Guess it's possible, if the stock end links were on the sway they may be at an angle and not perpendicular like they are from the factory. I had a similar sound once I lowered my car. Only happened at low speeds over speed bumps, or over into a driveway. Ended up going away, I did pack the bushings with grease though so that may have helped resolve it.
Old Sep 24, 2013 | 01:40 PM
Brandon302's Avatar
Does it sound similar to this?
Old Sep 24, 2013 | 02:02 PM
p0ny's Avatar
No, it's not a squeek. It's definitely a clunk. That's a good idea. Will see if I can make an audio of it.
Old Sep 24, 2013 | 02:48 PM
radioguy1's Avatar
I think I would get the dealer's suspension expert and take him for a ride with you. Usually once they hear it, while in the car, they can narrow down the cause.
Old Sep 24, 2013 | 03:13 PM
Mrsuitcase's Avatar
I know nothing about suspensions or mechanics; but.... here's a simple one to rule out.
... since you're a new owner, is everything in your spare tire compartment secured?
Old Sep 24, 2013 | 03:21 PM
p0ny's Avatar
Yes.
Old Sep 24, 2013 | 07:58 PM
Brandon302's Avatar
Also if you get under the car, shouldn't need to jack it up, and hit parts of the rear suspension with your palm and see if you can track down the noise. That is how I traced the noise on my car to the endlinks. And you can drive with the back seats down to hear the noise more clearly.
Old Sep 25, 2013 | 06:57 AM
p0ny's Avatar
no way to get under the car as it sits too low. Bringing it to yet another shop today and we'll see what they have to say. Thanks
Old Sep 26, 2013 | 07:44 AM
FordService's Avatar
Hello everyone,
Hi p0ny,
I see you have a couple of mods, but I’d like to get this escalated for you. This way your dealer and the customer service manager can work together to find where this noise is coming from. Please make an appointment and PM me with your VIN, dealer, mileage, full name, and best daytime number. Please remember, this may or may not be a customer pay repair.
Deysha
Old Sep 26, 2013 | 08:54 AM
p0ny's Avatar
Originally Posted by FordService
Hi p0ny,
Deysha
Hi Deysha, do you have a phone number I can reach you? if so would you mind PM me?
Old Sep 26, 2013 | 01:51 PM
stock shocks work for the stock springs, once you take them out of their useable range they tend not to work so well. I had that problem with a lowered car and when I replaced the stock struts and shocks it solved the problem.
lets say the stock shocks have a working range of 2.5 inches and when you drop it with lowering springs you take away some of the usable 2.5 inches. you might end up with 1 inch of usable shock and then after that you have nothing.
Old Sep 26, 2013 | 03:24 PM
p0ny's Avatar
If it were the shocks wouldn't I notice this clunk/knock on bumpy roads as well because I don't. Drives great all other times.
