Spring help
Old Oct 6, 2013 | 02:13 PM
DinoDoc's Avatar
Spring help
I was thinking about putting a set of springs on my car to lower it and stiffen up the ride a little, but I noticed most of the spring manufacturers have different rTed springs and they use letters for a rating system. Can someone help educate me on how the rating system works?
Lee
Old Oct 7, 2013 | 01:52 PM
Brandon302's Avatar
never seen a letter used to rate springs, who's springs are you looking at? Also think about shocks since the springs may stiffen but not remove the floaty feel stock shocks have
Old Oct 7, 2013 | 10:51 PM
DinoDoc's Avatar
FRPP's springs have letter designations if I read it correctly
Old Oct 8, 2013 | 05:40 AM
Brandon302's Avatar
Ford I don't believe posts their spring rates, but I see what you mean now, I would say that is more a part number designation then anything. This should help you determine which spring to go with based on rates and drop, http://bossmustangsonline.com/index.php?topic=5659.0
Old Oct 8, 2013 | 08:38 PM
Jay@Hypermotive's Avatar
Former Vendor
OP, how low are you wanting to go? Every FRPP spring set we tried (minus K springs) we liked. P springs are pretty conservative whereas the K springs are fairly aggressive. What are your goals?
Old Oct 10, 2013 | 01:39 AM
DinoDoc's Avatar
I was thinking 1" to 1.25" in the front and 1.5" in the back
Old Oct 11, 2013 | 06:14 AM
Bocefus's Avatar
Go with BMR. Perfect drop, nice ride. Camber plates not needed.
Old Oct 11, 2013 | 05:23 PM
mikeyt03's Avatar
K springs are way too stiff. When I had them, I got zero weight transfer, which gave me zero traction from a stop. Ive heard bmr is good in regards to weight transfer. Probably too soft though.
Old Oct 11, 2013 | 10:10 PM
Bocefus's Avatar
Yeah BMR aren't drag springs. I like them for DD.
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
