Smallest wheels to clear GT500 6-Pots?
Old Aug 16, 2013 | 04:50 AM
ForgotMyUsrname's Avatar
Is this the smallest (19")?
I'm not able to find any 18s that clear the 6pots unless the Vorshlag wheels do.
Old Aug 16, 2013 | 06:31 AM
1 Alibi 2's Avatar
These fronts are 17", with the correct offset & backspacing you can clear the front brakes.
Old Aug 16, 2013 | 09:31 AM
Well the wheel is all of 3" wide. I intend to turn with these.
Old Aug 16, 2013 | 09:56 AM
It's gonna take a 19" wheel
Just to clarify with 1 Alibi these are the 6 piston 2013/2014 15" rotor GT500 Brembos if I'm reading the OP correctly. Did you change your 11/12 14" rotors out 1 Alivi to the new ones?
I've got a 13 Gt500 and I can barely stick my index finger between the caliper and the inside of the wheel as it is with the stock 19" wheel.
Old Aug 16, 2013 | 11:55 AM
please do not try that while the car is moving
Old Aug 16, 2013 | 01:36 PM
Brandon302's Avatar
Pretty sure you can run 18's, blowfishracing.com has wheels that Steve says clears the brakes.
Old Aug 16, 2013 | 01:46 PM
I will be changing my 2014 Brembos to 2014 GT500 calipers, yes.
Old Aug 20, 2013 | 02:26 PM
RehagenRacing's Avatar
We have found that all the BBS 18" wheels that are offered by Ford Racing will clear these brakes.
We run this package on a couple of our cars already.
There are other 18" wheels that will fit over these brakes, but none of the other 18" Ford Racing.
Old Aug 20, 2013 | 04:07 PM
Mustang259's Avatar
Vorshlag racing also has 18's that will clear Brembo's and they are a light weight wheel.
Old Aug 21, 2013 | 06:48 AM
I thought Terry tried his two most common wheels and neither fit? I'll see if I can find his post online.
Old Aug 21, 2013 | 07:39 AM
We're not talking Brembo package Brembos. GT500 6-Pots are much larger.
Old Aug 21, 2013 | 10:57 AM
modernbeat's Avatar
That's right. Our Forgestar and D-Force 18" wheels will clear the 14" Brembo package brakes, but not the 15" GT500 brakes.
lowblustang00
Sep 5, 2015 12:18 PM
